After a fast 400 mile road trip, my Contour now stumbles a little when idleing or taking off from a start. If I gas it, it smooths out. Replaced plug wires, fuel and air filter before trip. Could it be the plugs? Any idea what plugs are best? Whats the gap? Thanks John
1998 Contour V6 ATX with 27,500 miles
You know you're in trouble when your Grandma flips you off.
Bumping up
Its your coil pack.
Pete
its not definitely your coil pack. i'd go with the plugs first. i had the same problem and it was solved with a plug and plug wire change.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
Forgive me for asking but where's the coil pack and whats it look like? Any idea on the cost of one?
its the unit that all your spark plug wires plug into. trace one and ye shall find. laugh
cost is about 80 bucks for an oe unit.
plugs are much cheaper and are more likely the culprit than your coil pack. get some autolite double plats.
-Dan
Thanks for the replies. Appreciate it. John
