#51783 01/17/02 01:57 PM
9
9
Have been hearing a strange groaning sound coming from the right front wheelwell. Seems like it only occurs when rebounding from a bump or when hit a dip in the road. It sounds like something is rubbing against something else. Could it be a bad strut?
#51784 01/17/02 11:43 PM
N
N
I had a problem very much like that. It turns out the front sway bar had moved ever so slightly to the left and was now rubbing against the lower control arm on the right side. By removing the wheel and using a crow bar, I pulled the sway bar back towards me just a little and the problem was solved. (Take the wheel off and look for a shiny surface which will indicated contact between two suspension pieces, which shouldn't occur. Remember, the rest of the underbody should be dull and dirty, so a shiny spot is a warning)
Hope this helps.
P.S. Be sure to check your front sway bar links. If you hear a rattling sound from the front end over small bumps and undulations that is a good sign they're bad. I've replaced mine twice now...
I also have a 95 SE smile
Other things to look for
1: The link that connects the secondaries to the valve that opens them, had to replace the plastic pieces that hold the link in place.
2: Front sway bar links
3: Rear sway bar links
4: Fuel door lid doesn't always open even after repeated pulls on the lever (clean around the fuel door lid and apply a little armor all or silicon spray, it'll never stick again)
5: Catalytic converter replacement
6: Low coolant light (add more coolant above full line)
7: clogged or dirty throttle body.
Not too difficult to fix them all, except cats but that was covered under recall.
7:
#51785 01/18/02 10:43 AM
E
E
I parked the car so there was more weight on the driver's tire. Used my friend as ballast until I got the right amount and gave it a good, hard tug. No more sway bar rubbing.
It was very annoying. I 'fixed' it a year ago, and it hasn't done it again since. smile
BTW, mine was rubbing the subframe on the front passenger side.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#51786 01/18/02 02:59 PM
F
F
Did you have the coil spring safety recall/fix done?
Mine started groaning right after the shields were installed.
The shields were rubbing against the inner fender (black plastic).
I made the dealer take the shields back off and the problemw went away.
forrest
