Light stays on for approx. 2 minutes of running. The last time this happened it eventually led to the water pump going bad but I'm unsure if they're linked. If they are then I'm wondering what could be causing it.
BTW I do that the metal impeller water pump installed.
Webmaster
Webmaster
Your coolant level is low. In the Contour world, that means it isn't at least a half inch over the MAX line. This is a FAQ item.
-Lance
Lance Kinley CEG Webmaster 95 SE, "Cassandra" 10 years!
