Posts: 15 |
I was making a right turn, and noticed a wwuuuwwuuuu noise. This noise only happens when I turn right. My dad came over and double checked my brakes, and they were good, and he did a short inspection of my struts and he said they looked fine to. I talked to my in-laws, because one of them is a machanic, and he said it might be the drive axel. I drive a 1995 Ford Contour GL 2.5.
If you can't amaze people with your intelligence,
Confuse them with your stupidity
Posts: 1,616 |
Originally posted by 95ContourGL2.5: I was making a right turn, and noticed a wwuuuwwuuuu noise. This noise only happens when I turn right. My dad came over and double checked my brakes, and they were good, and he did a short inspection of my struts and he said they looked fine to. I talked to my in-laws, because one of them is a machanic, and he said it might be the drive axel. I drive a 1995 Ford Contour GL 2.5.
A lot of people have experienced bearing failures when turning in one direction causes the noise to rise and turning in the other direction causes the noise to lessen.
Posts: 8,445 |
took the words outta my mouth..
NY State Trooper: So what makes your car so special to have SVT all over it?
Me: Er...It was made by Fords SPECIAL Vehicle Team?
Posts: 1,616 |
Originally posted by ElKy: took the words outta my mouth..
Rather get a grill...
Posts: 157 |
You should check the CV joints and boots.....
Posts: 33 |
Most likely a front wheel bearing failure. Don't know which one, I've had both of mine replaced and I can't remember which way I turned that the noise got louder.
I would think that it wouldn't be a CV Joint, you would hear a clicking coming from one side or the other if it was a cv joint.
Hope it helps, Mike
98 ford contour
CAI
Strait pipe from cat back
lots of neon
future plans include Turbo and NOS
and a body kit
Posts: 1,806 |
Yeah sounds like a bearing to me. My friends was doing the same thing and thats what it was.
Adam
Electric Red
95 Ford Contour GL
ATX Zetec
Born on 11/01/94
(The Official SCCEG Beater.) ![](/ubbthreads/images/graemlins/tongue.gif)
Coming soon... Micah's Pre98 SVT Front Bumper and SVT body kit.
**1BADTOUR**
Posts: 212 |
OH yes the infamous wheel bearing problem that we all know about on a personal level
1995 Ford Mustang GT
Magnaflow Exaust
Clear Corners
BBK Cold Air Intake
MSD Ignition
Alpine Security System
2 12' Alpine Type S Subs in Alpine Box
Sony 1100W Mono Amp
JVC CD/WMA/MP3 Deck
Sold!!!
1996 Ford Contour GL
Posts: 15 |
Ok, thanks for the advise.
Next question: Is it ok to drive on still? And is this going to happen to the other side, or is it just one side that goes bad?
Posts: 1,616 |
It'll get worse as you drive...and as all things..will begin to effect other parts. Its pressed in to place...and its a big *ss bearing. Seems like I remember about $80 from NAPA..and Ford charged me $180 to install. Its not that its hard, but you have to get at it in the knuckle to do it.
