Posts: 122 |
Originally posted by unisys12:
If you are worried about other hard parts, like individual gears and what not, I really don't think there is an aftermarket supplier that has beefier gears. Just the differential. Which is really what you should be worried about.
I believe Quaif also makes gear kits for the mtx75. They are pretty pricey though.
-FD
1995 Contour SE
V6 5 spd
Posts: 1,977 |
Those are dog mesh style gear set. And yes, they cost more than my 3L Project, and definitely more than what my car's blue book value is.
Posts: 1,960 |
Originally posted by AirKnight: Those are dog mesh style gear set.
Aren't dog boxes designed primarily for racing apps.
Bless our servicemen & women overseas.
L.Cpl Ian Malone, 1st Battalion Irish Guards, R.I.P.
Posts: 1,977 |
I believe so, because I think you have to double clutch to shift or you'll be grinding all day long.
Posts: 49 |
Does the MTX-75 used with the 2.5 V6 Contiques have beefed up internals compared to the Zetec MTX ??
Does the Contour SVT use a version of the MTX-75 ??
Thanks...
Posts: 3,944 |
For the most part, all the MTX-75's used are the same for our cars. SVT's included. The Ztec does have slightly different gear ratio's though. For more detialed info on that check here.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 9,602 |
Originally posted by unisys12: For the most part, all the MTX-75's used are the same for our cars. SVT's included. The Ztec does have slightly different gear ratio's though. For more detialed info on that check here.
Duratec & Zetec MTX-75s have a different bellhousing.
Duratec uses a 4.06 gear
Zetec uses a 3.84 gear
Mid 2000 MY the MTX-75 was upgraded with stronger internals (syncros and gears) and the capacity dropped to ~2qts from ~2.6qts.
Also Ford changed the fluid spec at/around this same time to a 70-75W synthetic gear oil from Mercon spec ATF.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,977 |
Think I can safely put gear oil in the MTX-75?
Posts: 3,944 |
Demon, Thanks for correcting that for me. I have no idea why I did not mention the bellhouseing differences. SMACK!
Phillip Jackson
`98 Mystique LS
ATX rebuilt @ 151K
Posts: 9,602 |
Originally posted by AirKnight: Think I can safely put gear oil in the MTX-75?
Do you have a revised MTX-75?
If you do and live in a hot weather climate then running the synth gear oil would be a valid option.
I would recommend Mobil 1 gear oil.
I have thought about trying it out this spring. I'm due for a fluid change (2 years) anyway.
BTW - I finally answered the original topic question in my last post.
2.6qt & 2qts respectively.
2000 SVT #674
