Page 6 of 8 1 2 3 4 5 6 7 8
#517137 01/09/03 09:59 PM
Static Offline OP
Oh I know he wont I will bug him about it forever to... sorry about the confusion james...
Oh man oh man 100 post in one day that is a lot of typing... well I take that back cause all he types is "LMAO of these " "
Hahaha... Adam man we are just giving you a hard time man... dont take it wrong lol {
Trollin the boards as of 9/23
Originally posted by GS474:
stock hp is never enough
#517138 01/09/03 10:00 PM
Stevers,
your sig rocks. . .
#517139 01/10/03 03:59 AM
Originally posted by Munch:
If I did the numbers right, a 24mm hollow bar would have to have a 9.5mm (~3/8") wall thickness in order to have the same torsional rigidity as a 22mm solid bar, assuming the same material (i.e. shear modulus) in both bars. But, with the hollow bar, you'd save about 2 lbs. for every foot of bar length (if it's made of say, steel). Assuming the bar is say 4 ft long, that's 8lbs. of weight savings using the hollow bar. Hey, every bit counts!
Damn you two for making me think about my Mechanic of Solids class the last week of break! DAMN YOU TWO!
Now, why does torsional rigidity really matters that much??? I thought it's the lateral forces are the ones that the sway bar are there to prevent? I mean, the sway bars are there to reduce chassis flex when cornering, so it's compressed left to right? So shouldn't you be more worried about the direct shear and stress?
#517140 01/10/03 06:29 AM
Because since the bar is bent at a 90 degree angle on both ends the middle section of the bar is what actually does the resisting. Thus in the 90 degree translation of energy it would in effect be exerting a twisting motion on the center section of the bar.
#517141 01/10/03 01:50 PM
100% Correct.
Airknight, I suggest you better go study some more!
#517142 01/10/03 03:50 PM
b0x @dm1n
b0x @dm1n
One more argument about your post counts and I will have both reset to 0!
-Andy
Andy W. The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
#517143 01/10/03 04:41 PM
Power trip.
- Tim
#517144 01/10/03 04:47 PM
Originally posted by Corbett:
Power trip.
Forgive him god...he knoweth not what he sayeth...
#517145 01/10/03 05:17 PM
Not lateral forces, but lateral weight transfer of the car via vertical deflection of the suspension, which is resisted via the torsion of the swaybar, per Demon.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
#517146 01/10/03 05:37 PM
b0x @dm1n
b0x @dm1n
This isn't about a power trip. It's about trying to resolve stupid arguments and unsolicited attacks on fellow CEGer's. Lance has always a had a firm stance on the fac that he will zero post counts if arguing occurs. Not all the moderators have time to read all the threads so I do my part where it's needed.
-Andy
