#51656 01/16/02 01:01 AM
Roger C Offline OP
if my tire/s appear to thump on each revolution,could they be out of round?When moving at idle I can actually feel a 'bump' at each revolution.Tire rotation did not seem to help.The right front appears to have more noise than the other three.Could be that is where I focus my ears.
If not the tires what in the drive train might cause the thumping/bumping feeling?
(Michelin x-ones on all four wheels)
stock 95 LX,6cyl ATX
#51657 01/16/02 01:12 AM
Sounds like a tread separation. Did you visually inspect the tires for any bulges or other irregular wear?
Dan B.
#51658 01/16/02 01:54 AM
I'll give it a shot... laugh
Without hearing/feeling what you're talking about, I'd consider one or more tires of inconsistent quality (although Michelin is often highly regarded for quality), or a bad bearing to be the most likely culprit.
If you're "feeling a bump" while rolling along at idle, you ought to be hopping all over the road at highway speed, or at least at certain speeds where the suspension resonates. Even if the wheel is perfectly balanced, an out-of-round tire or wheel is causing the suspension to move, which transmits vibration to the chassis.
Get your wheels spin-balanced, and watch them from the side as they spin in the machine. Any significant out-of-roundness would be visible. (Of course, the center hole in the wheel could be off-center while the lug holes are properly located... confused )
Garrick
Silver E0, #3895 of 6535, built 10/2/97
She's stock. Why mess with a good thing? laugh
#51659 01/16/02 02:37 AM
F
F
if your tire isnt visibly bubbled then you may have a bent axle
#51660 01/16/02 10:12 PM
4
4
I'd suspect the Drive Axles/CV joints or bearing if you hear the noise at very low speed.
98.5 SVT
93RX7
86GT 377ci
#51661 01/16/02 10:21 PM
Kai Offline
I rencently developed the same problem after changing to SE rims. Shouldn't be the bearing on because it didn't do it before. I suspect the tire, and am waiting for them to wear out.
Kendall
'97 GL Zetec ATX
" Nippy "
#51662 01/16/02 10:43 PM
MFE Offline
Did you lock them up recently? If so, you flat-spotted them. Nothing you can see but you sure can feel it. If you notice it more when the car is first driven then it's because the tires are cold and the flat-spot they got from being parked is taking a while to work itself out. If they're actually going thwack-thwack-thwack-thwack then it's a ply separation in the tire and you want to get it taken care of ASAP. Try jacking each corner up so the tire is just off the grouns and spinning the tire, while watching the gap between the tire and the ground. Any out-of-round issues will become immediately evident.
Pacific Green '96 Contour LX V6, loaded
'98 Grand Prix GTP 14.88/91 bone stock, awaiting new times from 3.4 pulley, CAI, U-bend removal but it's creeping up on the...
Calypso Green '92 Mustang LX coupe, 13.56/101
3-time local class champion autocrosser
Racing school whore
#51663 01/17/02 12:21 AM
Recently our Caravan suddenly developed a vibration that was felt at all speeds. When I jacked up the RF wheel, I found a very noticeable bulge in the tread. New tire time. There was no internal tire damage, but there was a bulge in the tread, nevertheless.
#51664 01/17/02 02:53 AM
i've got a thump...need new tires. Rear passenger is starting to show signs of seperation. Check it out man!!
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
#51665 01/17/02 05:19 AM
If it is only a slight thump and it is only there when the tire is cold, it could be that the tire has taken a set from sitting overnight. If that is what it is, it goes away after driving a mile or two. Tires with nylon cords in the sidewalls are the most prone to this. The Goodyear Eagles used on early Mark VIII did this and Ford's recommended cure was to install Michelin tires.
I am more prone to think that you do actually have a tire problem though. The advice to check the tire condition, especially for bulges and seperation, is excellent advice. Michelin has not been ammune to such problems.
Jim Johnson
98 SVT
