98 Contour SE V6 MTX
I checked the fuses and the bulbs and they're fine. A service manual for the contour says there's a relay for the fogs that's located in the "Interface Module Bracket". Unfortunately it doesn't say where this bracket is. Any help locating it would be appreciated so I can check the relay and maybe get them going again.
Thanks
RRW
98.5 Contour SE2.5MTX Black, Black & More Black Alpine 7939, MRV-1000, MRV-T300 Boston Pro 6.5s 3x JL10W6
Check the fog light fix in the FAQ's~if I remember there is a hidden fuse under the drivers side knee plate...
Check the bulb!
TGO Offline
Originally posted by AirKnight:
Check the bulb!
Anyway, IIRC there's a relay in the wires that are going to the headlight switch, but it's been a while since i've done the fog light mod.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
U
U
If you remove the panel located below the steering wheel and look up, towards the rear of the light switch, you will see a white relay that will possibly be taped up to the wiring harness.
You can pull the relay down and hold it in your hand and turn the fogs on and off. If the relay works, you will feel and hear it click. If not, then the relay is bad.
Hope this helps you out!
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
Mine didn't work as well since i blew a fuse while trying the fox light mod. I didn't blow the fuse in the box by my right knee, but a fuse found inside the box beside the battery. Worked for me. hope it does for you.
