Q
qaz Offline OP
Q
any ideas? coolant was recently changed. it worked fine (light did not come on) before that.
How many miles ya got and what coolant you using ?
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Remove the coolant res and the 'sensor' ,clean the gunk off the inside of the res and sensor,refit & refill.Any gunk can cause fale readings to the optical sensor,if that fails need a new sensor,dirt is the main prblem.....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Q
qaz Offline OP
Q
I've got 123,000 miles and I'm using the green stuff.
I noticed it was fine this morning, but the light came on after about 10 minutes of driving. It's been doing that since they changed the coolant.
I'm going to try cleaning the reservior, but how likely is it that air is still trapped in the system and the bubbles are tripping the sensor?
Brian
This is apparently a common problem with Contours. My '99 SVT had an intermittant coolant light warning even though the coolant level was on the mark and the car never overheated. I spoke to a Ford service technician, and all he could say was, "Yeah, we see that a lot." The fix: they flushed the coolant tank. Sure enough, once refilled, the light never came back on. Go figure.
Q
qaz Offline OP
Q
Someone on another thread mentioned that the sensor trips if the specific gravity (coolant concentration) isn't high enough (how they figured this out I'll never know, it's not in the shop manual and it's not in the user's manual).
So I got a coolant hydrometer and sure enough, one of the 5 balls didn't want to float.
So I pumped out about a quart of fluid and added a quart of concentrated coolant.
I went for a 20 mile drive and the light didn't come back on, so I think it's fixed.
Brian
I've also heard here (yesterday actually, you can search for it) that the sensor is positioned a little high and if you fill about a half inch over the max line it'll take care of the light...
[[Justin]]
'98 Silver Frost SVT
#2089/6535
I am made of cheese
My car is in the shop
When I drop the clutch, I get wheel hop
Do not eat me, oh please
Mine does the same thing. It seems to do it more often when the car is parked on an incline and then is started.
2000 SVT # 1418
95 Center Console
B&M Shifter
KKM Edelbrock 5503 Resinator Replacement
16" Focus Wheels and tires for winter
Custom Grill inserts
