Page 2 of 2 1 2
#51398 01/12/02 10:53 PM
Interesting...
Don't forget that it is normal for your brake fluid level to go down slightly as your pads and rotors wear and the calipers have to travel further (thus, you aren't really loosing fluid--it is just relocating). If you top off your brake fluid and then replace pads/rotors, you'll find that your reservoir will overflow.
Disclaimer: I'm not a brake guy, so I probably didn't describe the system quite right, but I believe that the basis concept is correct.
1999 Contour SE Sport MTX75 T-Red/Grey
Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1
Other: cup holders, cargo net, Blizzaks, Potenza RE950s
#51399 01/13/02 08:25 AM
E
E
Mine comes on every time I drive right now. Its starting to mellow out now the snow is melting and the temps are rising. It will do it if I go to a automatic carwash with undercarriage spray.
Mine disables the rear wheels first, then eventually the fronts too. Someone mentioned that there was a TSB for the ABS. Apparently there is a waterproof connector under the car somewhere that, well, isn't. The water gets inside and then the short between the connections freak out the ABS.
I find it funny, Ford put ABS on our cars as a safety feature. When it snows/rains/etc when the ABS is most needed, the moisture turns it off. :rolleyes:
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
#51400 01/15/02 12:40 AM
1
1
So, you think it's moisture? The damn thing kept lighting up everytime I drive.
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
#51401 01/15/02 07:38 AM
E
E
When I finally wash the little beast I will have to climb under and follow the wiring and find out. smile
This will probably happen when I install my Aussie Bar.
· Jon Miconi
Page 2 of 2 1 2
