Well I tried the throttle hang fix and it worked, the throttle did not hang anymore. But after a few weeks the cold idle got worse (the car wanted to stall in the morning) and last Thursday (1/23/03) the car would stall when stopped even when the car was warmed up. I would have to keep the RPMs up around 2000 when the car was stopped to prevent it from stalling. I replaced the idle air control valve today and now everything works fine. No more throttle hang and no more idle problems. The car also seems to have more power, especially in the mid RPM range. It seems to me that the throttle hang fix reduced power in the mid RPM range. I have no real proof other than the car felt much quicker in the mid RPM range.
I am not saying that all throttle hang problems are the idle air control valve but mine definitely was. I would still try the throttle hang fix first to solve any throttle hang problems since it so easy and cheap and if it works great. If it doesnâ??t, I would replace the idle air control valve next. The valve costs around $60.00 and is also easy to change (not as easy as the throttle hang fix though).
Thanks for all your help. This site is a great since most Ford dealers are really pretty bad, except for you BigJim
