CART99 Offline OP
I have to kill the moose this weekend. How do I reset the computer after I install the copper end cap with the hole in it? Do I just disconnect the battery?
Thanks in advance.
Russ
1999 Red SVT #1194
"CART 99"
E
E
The best i have found is disconnect the battery and the #4 and #11(under hood) fuse, for about five minutes. Then connect all of them back up and start your car, let run until idle goes back to normal.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
Do one or the other - both is redundant.
Pulling fuse #4 and #11 is the best.
You can also pull fuse #9 to be sure.
Disconnecting the battery will erase all the settings in your radio and we all know that a properly configured radio is worth 50 HP alone.
I would hate to have to tweak my radio all over again.
When you have had the fuses out for at least 5 minutes, reinstall them and then start the engine.
The engine has to idle with ALL of your accessories OFF, until the cooling fan has come on.
Then you can get in it and go driving again !
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
CART99 Offline OP
thanks!
Russ
1999 Red SVT #1194
"CART 99"
