L-Train Offline OP
Got my car in April or May of 2001!! Its a 98 and I've had numerous alignments made and both tie rods replaced and now my car has the same feeling it had before when my first tie rod needed to be repaired!! mad Should these things be coming off so quickly or being repaired so quickly??? I've only got 45k on the car!! Should I be bustin in on the dearlership where I got the car and raising Cain on the lemon I got???? I was looking at CarFax and there is 6 reports on my car and I know I haven't had any wrecks!! I need some feed back fellas!!!
98 SVT switchin 4 lanes windows down system pumpin screamin out money aint a thang!!! laugh
9
9
You don't actually say what problem the car has. Does it pull to one side or the other? Under braking? Or not? Anyway, you could have the old rear lower suspension arm bushing problem that the Mondeo group mentions on their website. I don't even know if the Contour shares suspension engineering 100% with the Mondeo or not but it's a place to start since replacing tie rods isn't doing it for you. In short, the rear bushing is a split design (the front is solid) and prone to failure rendering alignments unaffective. Check it out. Anyone want to second this diagnosis?
Karl
*** It's all about consistency! ***
98 SVT Contour
86 Ranger GT
69 Fiat 850 Sport Spider
67 Formula-S Barracuda
Hey man - YOu should take a deep breath for a second. ppphhhhheeewwwww!!!!!
ok. seriously - don't worry too much about the carfax until you know EXACTLY what they six records are. Please remember that carfax keeps track of things like sale date, title transfers, lease trasnfers, etc....
Now the tie rods. I had the similar problem with my SE. They did go out fast - but haven't in about 60K miles so I think I'm golden for a while. I'm not quite sure what parts the tie-rods work with but maybe it's something else that's bad that's causing the tierods to go out prematurely? just something to think about.
good luck with the repair!
smile
Just had to replace one of my tie rods at 55000k. Fortunately was under warranty. Left side seems to be OK so I don't know if it will be a recurring problem.
99 SE 2.5 5spd
Tie rod ends are crap on this car. Mine were SHOT at 50k, dangerous to drive on. Replaced with MOOG, greasable with a lifetime warranty. Not so worried about these...
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
i had an old taurusaurus that had the tie end rods replaced due to wear and the car was so much nicer to drive afterwards (the right front wheel would feel like it was on a spindle or was wobbling around like a bad shoppin cart wheel)...the repairs started to slip after awhile somewhat (the car started to loosen up on the front end) and that when i found out the the inner tie rods (ends?) were bad as well but i never replaced them
could this be the problem with ya contour too???
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
