Page 2 of 2 1 2
Question: Is the "grinding" happening while you're trying to pull the lever into second, or is it when you let out the clutch?
I've had the latter happen when trying to engage reverse. Basically, I have a hard time getting the lever to move back as far as it should, and basically it would appear I haven't fully engaged the gear when I let the clutch out... buzzzzz.
If this is your situation, I'd suspect there's interference between the shift lever and some other part when you try pulling the lever down and toward you.
Now, I digress... In my case, I've decided the problem was a clutch that wasn't completely disengaging. In such a case, the synchros would still be able to overcome the dragging clutch to synchronize the gears, but if the dog teeth aren't properly aligned, you're SOL (double-clutching or pushing the lever into another gear may be necessary). For the time being, I think bleeding the clutch may have cleared this up (since air in the clutch slave cylinder would result in less clutch plate travel).
I guess what I'm trying to say is, might as well bleed the brakes and clutch while you're troubleshooting... Can't hurt (unless you do it wrong). smile
Garrick
Silver E0, #3895 of 6535, built 10/2/97
She's stock. Why mess with a good thing? laugh
Originally posted by PhatSVT:
well it could be your synchros, but it may be just the problem a lot of SVT's have is going into 2nd gear period. ever since i have owned my Contour SVT i have trouble getting it into 2nd gear. especially with the weather being cold it never wants to go in gear.
I would agree. Sounds like a bad syncro problem.
The best thing to do now is drain the fluid and put in the tranny Cocktail and see if that helps. Instructions can be found in the FAQ section...
2000 SVT #674 - Check it out!
Page 2 of 2 1 2
