Page 2 of 2 1 2
Yea, I just used a deep well socket, extension and rachet. It is a close fit but you can still do it with these basic tools!
I did mine at 50K. Took about 2 hours with ordinary extensions and a ratchet.
The original plugs looked OK except for the front ones from each bank, which were severely eroded.
Recommendations:
- cold engine
- blow out spark plug head hole with air before taking out old plugs
- use a locking extension with a socket with the rubber inside
- think twice about using anti-seize compound on threads
- use small amount of silicone grease inside plug boots
Dan B.
No offense, but if it is taking you guys upwards of 2 hours to do this, you are trying way too hard. I change my plus every other oil change (N20 does a job on em) and I can do all 6 in 30 mins.....
1991 GVR4
Lots of mods done.
I wonder if different years/models have different amounts of room along that back wall. All I had to do is undo one clip on the distributer and I was able to get to everything just fine. I have a 96 SE, maybe the SVT is different.
Also, don't forget:
- Dielectric gel.
- Torque the spark plugs to the proper rating, being a farmer here could set you up for some problems later.
- The forum seems to be split on anti-seize, I don't use it myself (just to darn lazy) and everything works fine for me.
- Don't get dirt or other junk in those holes
I do have a question myself though, my Haynes manual says the torque rating is 84 to 180 in-lbs. That seems a bit vague to me. I used 120 and everything is holding together just fine but does anyone have a better number to use?
Scott
96 SE, MTX, BAT 22mm rear anti-sway bar, BAT springs and Spax struts
96 Caprice, 9C1
Rayon is made of wood!!!
tiny1 Offline OP
thanks for the input. the garage wanted 50 bucks for plugs but no wires ?1? mad but I think saving a few bucks is worth the effort! thanks laugh
95 contour gl
2.5 v6
p.o.s. car (LOL)
Page 2 of 2 1 2
