Page 16 of 24 1 2 14 15 16 17 18 23 24
#508129 02/11/03 07:33 PM
I got mine today also.
1998 T-Red SVT Contour #2588 of 6535 2005 F-150
#508130 02/11/03 09:42 PM
I got mine also......it's the ssk-0004 Focus shifter though....it had the sticker in the box
06 GMC Sierra 2500HD Dmax/ally 06 Pontiac G6 GT 05 CRF250R FOR SALE 06 KX65 with riding gear $2700 obo
#508131 02/11/03 09:58 PM
6
Just put mine in took about 30 minutes. Very easy to do, the only bad thing about it is that when you go into and out of 5th gear you have to pull up on the reverse lock out. No big deal to me. Looks and feels great!!!!
Later
Josh
New car: 2004 Mazda 6, V6 sport Former car: 1998 Ford Contour SVT 1968 Dodge Charger R/T (General Lee) www.confederategeneralleefanclub.com
#508132 02/11/03 10:01 PM
Uh HellO! It's not supposed to be like that! !!!
#508133 02/11/03 10:01 PM
O
O
I WANT MY STICKER!
MY NEW HOBBY...RUINING CHRIS CROFTS LIFE...
#508134 02/11/03 10:02 PM
Is it ugly w/o it?
#508135 02/11/03 11:27 PM
got mine today and guess what
I GOT THE STICKER!!!
i was leaving and some guy in a van pulled up behind me and just sat there until i got out and then he gave it to me.
why do you ahve to use the lockout in 5th gear? that sucks.
someone post instructions please.
thanks marckus
"What did you think about that Dorothy girl?" "The whole Judy Garland thing kinda turned me on. That doesn't make me some sort of fag does it? "Nah baby, your money." 98 Black SVT #3560 of 6535
#508136 02/12/03 12:28 AM
6
Well it is really easy.
1. remove shifter knob, and plastic shaft with boot.
2. remove retaining clip in left corner of the plate. (gold on the side of shifter mount) pull it loose carefully.
3. remove bottom linkage (I used a screwdriver) should just pop right off.
4. Then remove torx screws (4 of them).
5 The shaft and everything should come out at this point.
6. remove the black rubber boot and the thing that holds the ball. Put those things on the new shifter the exact way the came off. Becareful!!! Grease up the ball I used bearing grease which is the same as the stuff that is in there.
7. Reverse the process and you are done.
Oh the shifter boot. It is held on the to the shaft with a wire tie. Just cut it out and thread it with a new one and put it on the new shaft and you are done.
Any questions just ask.
Let me know if anyone else runs into the problem with 5th gear.
Later
Josh
#508137 02/12/03 02:38 AM
i think you might have put it in wrong if you need the reverse lockout for 5th gear... i will find out more tomorrow.... hopefully when i get mine....
98 SVT #4636/6535 T-Red/midblu http://www.pbase.com/markussigpi/galleries FOR SALE: My Car.....
#508138 02/12/03 02:48 AM
not the dreaded "5th gear lockout"
Black 98.5 SVT "Kellie" First rule of italian driving: What is behind you, DOESN'T matter
Moderated by  1314_dup1
