It most probably is an alignment issue, however, it could also be the result of incorrect tire pressure or uneven tire wear, as well. At least start by checking tire pressure. If all is well, get the alignment done.
Only take it to a reputable shop for an alignment(preferably NOT the shop you had your brakes done at!!
), so my advice to you is go to where a friend would recommend having service done.
