Hi NVS, Mystique, you know, I had a Mystique V6 before the CSVT. It was a 99 with CD4E transmission, with all options excpt the traction control, it was a beautifull car but I think I,m not old enough to own one of this kind. For sure it was a mystique stock , no mods except for the sound system.
Your Mystique is so nice man, I hope I will see you one day. I,m a very big fanatic of Contour and I,m a mechanic so if I wanna modify my car It will be easy for me.
Yeah , I have problem with the camber, the tires that I will remove from the whells next spring are beared by the inside, it,s scrap. The wear is also in diagonal that means that the caster is no good too. Do you know about the possibility of a camber kit for the rear struts, I checked on BAT or CTA motorsports and it seems that only the front ones are available.(300$ for a front kit)
For winter, I put 15" steel rims but I put back the OEM front brakes. Pascal gave me the calipers with holders so I bought new disc and pads for a Cougar it,s the same except for the wires on the pads that I cut.
Next spring it will be the time to do a really sporty car with my SVT. I will change plugs, plug wires, clean the upper and lower intake manifold and buy an air Intake kit.
I will probably need your help for a couple of things
Do you speak french, moi je parle en francais et je suis pas mal plus a l'aise dans cette langue d'ailleurs. We could talk about that on the CCMQ. Are you member on that site ,what's your name ?
See you boy
