I changed the pluged and wires as stated in my update post above... that took care of most of my problems, but the surge in lower RPM's (below 2000) has returned. It has a noticable rough idle (well I notice it anyway, I took it to a mechanic friend of mine and he said that he thought the idle was fine) and if you raise the RPM's to 1000 it is very noticable. Above 1000 it is smooth as silk!
I was plaining on cleaning my TB again today, figure that it is due since it has been about 8k since I did it the first time, but it has rained off and on all day so that will have to wait.
I must have a vaccum leak somewhere back there, I just can't find the rotten thing! I have done everything I know. Even went so far as to try spraying carb cleaner on the lines to see if the idle changed. I will most likley be replacing my UIM gasket soon anyway because I do notice what looks like oil seeping out of the UIM to LIM area. I replace my PCV valve too!
I don't know!
I will let you know what I do the fix even it is means taking it to a shop!
