Posts: 287 |
alright....if im free later ill stop by
04 Blue WRX
-Rota Subzero's 17in gold,Cobb Tunning Stage 2 93 octane, tein springs, 3in -turboback with magnaflow muffler + 1 resonator  2 1/4 up-pipe Former owner of Conniethecontour 99 CSVT...My first love
Posts: 873 |
Originally posted by Connie: wow..........you must have a lot of free time on your hands....also......main reason people put there battery in the trunk is for a cleaner look under the hood and so its better for the air filter to get air a big plus......and HEAT SOAK sucks...
Yep! Plenty of time...hmm, cleaner look, maybe if you show the car, but I race mine. Hmm, last time I check the battery had nothing to do with my filter getting air. Try putting a heat sheild around your filter or (here's the big one) move your filter to where it gets cold air. BTW, I'm just messing with you. Obviously moving the battery isn't for everyone, if it works for you, great.
2004 Focus PZEV 2.3L - KW sport suspension, SP camber plates, Eibach front swaybar, FS intake, FS Stealth exhaust, 3.82 Final, Torsen ATB, Prothane MM insert, E1 CSVT wheels
1/4 mile - 15.201@89.4mph
Posts: 2,353 |
Another reason to move the battery to the truck instead of getting a dynabatt is that the little dry cell batteries don't have as much cranking amps. If your planning on having a fairly large stereo system and/or live in an extremely cold area, you need to at least have as much power as the stock battery.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 873 |
Originally posted by path914: Another reason to move the battery to the truck instead of getting a dynabatt is that the little dry cell batteries don't have as much cranking amps. If your planning on having a fairly large stereo system and/or live in an extremely cold area, you need to at least have as much power as the stock battery.
The stereo part I can't help you with, but most of the dynabatts have really good CCA's. Moving a battery to the trunk decreases its ability to start a car as well due to the fact that you have to transmit that much current over a fairly long distance through 0 gauge wire. You'd have about the same effect as having a dynabatt in the front.
Posts: 2,353 |
Not if your going with an optima like most do. Also, the distance doesn't affect the charge significantly if you have a decent 4 gauge or larger wire. I have yet to see a small dry cell battery that has any more cca than the stock battery, although that is just me. The only one I've seen or heard of is myfastse's that weighs about the same as stock and has 1000 cca.
2003 Suzuki SV650s
Posts: 873 |
Never said it had the same as stock...but I did say close. I probably should have said enough. You can't be serious that you don't think transfering current through 15ft of 0 gauge isn't going to reduce the ability of the battery. Now if you have 4 gauge (which you shouldn't) then yeah, there won't be as big of problem.
My whole point about this is that moving your battery all the way back to your trunk bought you just about nothing other then an extra 5lbs over what you could have gotten with a much simpler install and one that is just as clean. Now we can argue all day over this but I've stated my opinions and backed them up. It is great you guys think that moving it is better, but I disagree. I feel the risks for reward are much too great.
Posts: 287 |
If you dont like it or do like it than thats cool.......everyone has the right to say there .02 cents.......The only thing that upsets me is when people say things that they have no idea to what the answer is and think there right  ......
04 Blue WRX
Posts: 970 |
I always thought the reasons for moving a battery into the trunk was either for space for an intake (cold air or otherwise) or to make room for a supercharger or turbo.
98 GL sport (V6 MTX)
The Durable Duratec? - (DMD, Metal impeller WaterPump, Synth & Stinky in the tranny)
Posts: 873 |
Originally posted by Connie: The only thing that upsets me is when people say things that they have no idea to what the answer is and think there right ......
And when did I say anything that was false?
Posts: 2,353 |
Qbert: I don't think anything you said was false, just a contrasting opinion. I personally think both sides offer good solutions with different trade-offs.
2003 Suzuki SV650s
