I would try the TH fix if you are experiencing throttle hang. If the car is moosing I would change the IAC. If the valve gets stuck closed, you will not be able to start your car...well...unless you keep your foot on the pedal to feed it air/gas.
1999 Silver Frost SVT
#609 of 2760
