Posts: 122 |
Not sure of the year just yet (me thinks its a 2002 MY block) but I am getting it for a STEAL!
Based on my incessant interrogation of RTStabler...I found out a long block is everything +heads - cams - intake
Looking at the 2002's specs, I get 200 hp and 195 torque. Dreamy. 9.4 compression.
Now, the question is; what good would the SVT cams do, and what all would I need to replace/upgrade to get them in there? What things would you guys recommend I do to the engine, to get it to that lofty 225 hp?
Thanks!
~Scoriox
Posts: 122 |
BTW it is indeed a Duratech. Forgot to add that in there as an FYI.
~Scoriox
Posts: 3,732 |
with that low compression superchaarge that bastard !
Russell
Oval Port 3L Nearly Done
Posts: 5,810 |
Did they reduce the compression from 10:1?
I wasn't aware that they did. Why would they?
warmonger
See My Mods
Posts: 2,230 |
me interested.... reminder on this one
MY NEW HOBBY...RUINING CHRIS CROFTS LIFE...
Posts: 158 |
Where are you getting this and is there more available? PM me with the price and where they are if there are more available.
98 SVT
18" Enkei RS6's, NITTO 555 Extremes
Intrax lowering springs
K&N filter
Sho-Shop Y pipe (without cats)
Stock "gutted" manifolds
Carbon Fiber Cowl hood
Carbon fiber sail panels
Learned patience the hard way
Posts: 2,454 |
FYI guys the newer 3L's have the oval port manifolds and heads so unless you want to do the fab and machine work to make your 2.5 manifolds work or the fab work to make the 3L UIM work you're best off going pre-2000 on the engine and then using an electric W/P and controller. Just my .02
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180
Buckshot77@msn.com
Misc 3L parts for sale
Posts: 1,055 |
buckshot, do you have to use the controller, or is there a cheaper option?? thanks.
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Cool Toe Chris
Cool Toe Chris
Posts: 1,825 |
Originally posted by 96zetec: buckshot, do you have to use the controller, or is there a cheaper option??
thanks.
With the controller, the pump will run intermiently, based on the feedback from the temp probe. You can also set the thresholds manully.
If you don't have the controller, you can set the pump up to run on full blast, thus shortening the life of it, plus it cools so well, that your motor will never get to full operating temperature. This is all pure experience as my controller was dying (actually the temp probe was shorted out) and the controller defaulted to safe-full 12v mode. I installed a new controller (warantee from Davies, Craig) and everything is good now. They sent me a new controller, which included all of the wiring and the temp probe.
Chris
NJ
98.5 SVT Silver Frost
Redneck Troll
Redneck Troll
Posts: 2,621 |
Or, if you're an electronics wiz, you can create a temp sensor enabled, varied resistance circuit to have full control from the cockpit. Even someone with enough electronics knowledge of the engine wiring could do a two way relay connection and use the fan switch as the trigger to go from 8V to 12V.
http://www.bnmotorsports.com
