Posts: 1,249 |
How do i turn on my fog lights without turning on my headlights? I see a few other contours with this mod. Its when the turnsignals, tail lights and fogs work but no headlights. If anyone can help it would be a great help thanks.
1999 SVT black
And a Blond Haired Blue eyes girlfriend. How can it get any better?
Posts: 4,693 |
There is or was a FAQ for this modification. Check the FAQ's.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 1,247 |
www.contour.org/mods/mods.php?s=howto That's where I looked when I did mine.
Irfan Rahim
irfman2000@yahoo.com
2006 Blue Nissan Sentra SE-R Spec V
Former owner of a silver 2000 Contour SE Sport ATX
Posts: 176 |
Could someone please confirm that the Contour light switch can be pulled out once (Front Fogs) without being turned to the Dipped headlight position, this Faq seems to confirm that you can have the fogs on without the Headlights at all, The UK Mondeo's light switch cannot be pulled out without first turning it to the first light position.
Thnx
Neil
Mondeo (UK Model) GhiaX 2.5 v6
DMD 2003 Version
GhiaX 2000 Spec
Semi Automatic Climate Control
Power Folding Mirrors, Japan Stylie
Ford OEM RSAP
Latest Sump Revision
Posts: 1,412 |
You can pull the ConTique's headlamp switch out without the headlamps being on, but the foglamps don't turn on. The low-beam headlamps must be on for the foglamps to work. That is, unless, you have done the foglamp fix.
Posts: 176 |
Ummm, Must be a different switch, does the Contour have a parking light position, on the Mondeo this is a push in and turn to the left.
Thanks
Neil
DMD 2003 Version
GhiaX 2000 Spec
Ford OEM RSAP
Posts: 3,627 |
you guys are making it hard on the guy. all you have to do is get your fog wire and splice it in to the parking lights. then when your parking lights come on your fogs will to. or you can do what I did and make them DRL and just splice them into your ignition
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 1,939 |
I just did it Static's way earlier today...hmmm...strange timing. I ended up using a relay, though. tapped into the pass. side parking light (+) wire, used it as the "signal" wire for the relay, one wire to batt. (+), one to batt. (-), and then a y'd off wire to the two foglight harnesses. Crimp splice (you know, those blue things that you stick the two wires next to each other inside and then mash with some pliers) onto the (+) (Orange wire). The harness is already grounded. Took less than one hour, counting fitting the foglight assemblies. Pics of the finished product can be seen in Pics & Vids.
2000 Silver Frost SVT
# 1637/2150
D.O.B. 01/14/2000
Posts: 1,834 |
To try and answer the guys original question. In factory form, you can't turn on the fogs without having the headlights on. You must modify the wiring going into the switch to do this, check out the link to the how-to someone else already posted. To answer Neils question about the Contour light switch, yes we have a parking lamp position. The way our switch works you turn it one spot clockwise and the parking lights come on, turn it two spots clockwise and the headlights come on. Brights and dims are controlled by the turn signal stalk on the left side of the column. The knob can be pulled out when in the parking light position, but unless you've done the fog light mod the fogs will not come on.
Shawn Clone
Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose
Silver frost/Black Exterior-Midnight Blue Interior
The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot
I have 3 loves, my God, Brittany, and my Car.
Posts: 163 |
GEEZ, this procedure doesn't seem extremely complicated at all  .
2003 Hyundai Tiburon GT 6-speed Black
-former owner of a 1999 Navy SE Sport ATX
