Page 2 of 2 1 2
Instructions for cleaning the throttle body have been posted many times in the past both here and on the Contour-l list. Do a search and you will find a wealth of information.
Jim Johnson
98 SVT
Ry Ry Offline OP
Great, thanks guys
1996 Contour SE Red V6 MTX
1995 Contour LX Champaign V6 ATX (my wife's beater)
SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=3&t=003724
This has a post describing how to clean the upper intake, EGR ports, and TB. You could probably get away with just pulling the TB off the upper intake - you'll need a new gasket for this though. The real problem is right behind where the TB bolts onto the upper intake - there are three ports for the EGR that I will bet are completely plugged up with carbon. They were on my car, and I cleaned them out at about the same mileage your car has. I used to have pics of the clogged ports on that post, but my web server got screwed up. I still have the pics if you want to see them - just e-mail me at sting45470@yahoo.com and I'll send them to you.
Poor design of the EGR ports on Ford's part, IMO. Otherwise a great engine though. smile
'96 Contour SE, black / opal grey, MTX, every option, KKM intake, resonator removed, Flowmaster Series 40 DeltaFlow, GoodYear Eagle HP's, 115k miles, new paint 7/01. Driven cross-country 4 times.
'70 Corvette Stingray Coupe, Cortez Silver, 454 bored to 462, Muncie M21, too many mods to list, lots of fun. 335 rwhp / 365 rwtq
'02 Corvette Z06, Electron Blue / Black, every option. Stock for now...
F
F
The dealership here charges $74/hr...so that is something you could really save money on if you could do it yourself.
Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's*
B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers.
Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
What are the signs that your TB needs to be cleaned?
The reason I ask is because in the last 3 weeks my car has failed to start twice after I drove it about 3 miles to work. Both times it did the same thing. It starts up and then it dies. It will stay running if I hold the gas down. As soon as I let up on the gas, it dies. If I put it in 1st and drive it about 20 yards, it's fine. Anyone know what's causing this? This is a 99 SVT with 34,000 miles and a KKM installed.
Y
Y
Here's a pic of the back of a Contour throttle plate with 154,000 miles on it . I scraped a bit off so it would show how thick it was eek (1/16 inch or thicker) .
On this picture , you can see the carbon deposits in the EGR passage where the throttle body bolts to the intake (intake manifold on left , TB on right) . The passage is the small "U" shaped one under the large opening . It's almost totally clogged with hard stuff eek .
The rest of the pics are HERE
~~~~~~~~~~~~~~~Allen
********** Love Those REDWINGS !!! **********
2000 Contour SVT Black w/ Tan #2137 of 2150 / built 2-4-00
Mods : ~ Factory DRL mod ~ "Powered by Ford" seatbelt covers
~ OF's TH fix ~ Audi A-6 Side Repeaters ~ Highs in Lows Mod
~ #885 foggies ~ KKM filter ~ Mondeo ST200 Badging & Shiftknob
~ Pre-98 Sails ~ Nose Bra ~ Trunk cargo net ~ '98 Clock
~ "Glasspacked" Resonator ~ Painted Rear Reflector
~ Räzo Pedals ~ Custom "Mondeo" Windscreen Banner ~ Ventvisors
~ Lighted Moonroof Switch ~ Mystique Rear Seat Light
~ Painted Grille Ring ~ H&R Springs & Mondeo ST200 Struts
~ Mille Miglia "Cello" Wheels
My old 95 \'Tour SE ~ New SVT pics here
GREAT PICS !!!!
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Ry Ry Offline OP
Turns out it was the #3 spark plug wire. The shaft was completely spiderwebbed. Like it was shattered. No wonder it was running so rough, i was only running on 5 cylender's!! BTW, I did clean the whole upper intake manifold and the Throttle Body (dremel'd down the screws on that baby too) and it was just sick. I mean the carbon was CAKED on there, a good 1/8" thick easy. The EGR ports where completely clogged! I cleaned that out and the car ran a little smoother, gas mileage went through the roof (extra 50 miles to a tank, still a little lower than the normal 280-300, but better than the 219 i was getting!), even though it still ran rough (problem was the wires). So I found the problem when I was putting in some new Bosch +4's.
I had put in motorcraft OEM replacments at around 60k, but I figured it must have been a bad plug for it to run so rough. And the rough running was sporatic too - every now and then it would run smooth, but then it would get rough again, usually after the engine warmed up. I guess I should've just changed the wires at 60k with the plugs!
BTW, using a metal polish made that throttle body just shine!! smoothed out the scratches from the sanding too. I was sad to cover it back up when I reinstalled it back on the intake manifold! laugh
Page 2 of 2 1 2
