Ry Ry Offline OP
took my wifes 95 LX V6 ATX into the dealer the other day becuase it's been having a problem (see previous post: "mother #(*&%#$er", heh) and they're saying "Uh, the TB is clogged with carbon deposits. Looks like it's never been cleaned before. I also recommend a tune-up too." so I'm like: "ok, how much?" and he says $315!
So my question is, WTF is this carbon deposit crap he's talking about? I've never heard of this being a problem. The cars got 92,000 miles on it and I've always followed the maintenance schedule very strictly. Any feedback?
1996 Contour SE Red V6 MTX
1995 Contour LX Champaign V6 ATX (my wife's beater)
SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
The culprit is mostly the EGR. You can't really do anything about it. SVTs come with a teflon coating on the TB inside which cuts down on deposits but doesn't eliminate them.
What does the tune-up include? If it's plugs, air and fuel filters, and the TB cleaning, the price doesn't actually sound that bad (as far as service goes). But before you spend $300, try cleaning the TB and combustion chambers with ford's spray cleaner. It's $7 and an hour of your time.
-Louis
1998 Black E0 #3826, lightly modded
E
E
A Dealership explained to me that a tune-up only consists of the plugs and plug wires(if they need to be replaced). What actually really kills you is the labor to do these things. I'm doing a tune-up on my zetec in a week and its costing me $40 less than what Ford would do it for. Zetecs are easy and will take like 20 mins. at the most.
For the carbon build up, louisw is right. Do it yourself, that way its done the way you want it and its much cheaper.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
Ry Ry Offline OP
unfortuneately i've never done this before. I'm assuming this is the part (going inward from my KKM) just past the large rubber part between the MAF and what I assume is the TB. Am I on the right track? And if I'm this fresh about this project, maybe I should have them do it? They want $156 to just clean the TB
I cleaned my maf and tb in less than 2 hrs. I used non chlorinated brake cleaner. Just take your time, as you take everything apart, remember where it goes. Remember not to get any cleaner on any electrical wires. I only had 55000 miles on mine and it was f#*kin disgusting. All kinds of carbon buildup.
91 Honda CRX
Bilstein shocks, Tenzo R springs
96 Ford Contour LX V6 ATX
KKM intake, Ford Motorsport 9mm wires
All Kenwod Stereo System - 134db
KDC-8016 headunit, KAC-859 amp, KSC-BP210 bandpass, DualMags: 6.5" front and 5.5" rear
I
I
I would say that $80 of the $156 labor charged is for an hour of drinking coffee and shooting the sh*t with all the other techs.
99 Range Rover 4.6 HSE
Mystery Car??????
Ry Ry Offline OP
I'm just wondering how much I have to take apart. I mean, do I have to take the large butterfly off? Or do I stop just short of it?
All you have to do is just disconnect the rubber intake hose and manually operate the throttle while spraying. Ford makes an EXCELLENT degreaser/carbon cutter. Go pick some up from the parts counter.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
Im no Terry Hains but i took the throttle body off with no prob. just take your time dont destroy the little seal in between the throttle body and manifold. My car has 47,000 miles on it and the throttle body was descusting and it was sticking. I also put high octane in it all the time. save the money and do it your self.
98 csvt, no res, bm shifter, sho-shop intake.
"wherever you go there you are"
Definitely do it yourself. I'm pissed as hell at myself for letting Ourisman Ford here in Northern VA hit me with some $400 in labor charges on it. Granted, I thought I had a bad starter because I couldn't get the car to start (somehow it went from "not starting" to "starting but stalling" while it was being towed). At any rate, lesson learned.
