#504660 12/20/02 02:36 AM
tgrimes Offline OP
I had a chance to drive a 97 SE the other day and it handled better than my 98 SVT. What gives??? Has anyone else had this problem. My suspension is stock, I have 67K on the car and I recently had a 4-wheel alignment and replace a tie rod with a factory ford part. I also replaced all the rear sway bar hardware with new ford parts. Please help!
Timothy Grimes 98 SVT #2132 82 320i -Now armed with a hairdryer-
#504661 12/20/02 04:48 AM
replace everything w/ aftermarket. get poly bushings, bigger sway bar, and if you have the cash, replace all struts,springs,etc. probably your suspension is just a little more worn than the SE, or your car was made on a friday come drive my GL, i wonder if it handles better than your svt (i have svt sway bar, and it does handle pretty darn good).
#504662 12/20/02 05:22 AM
The 95 to 97 SE has stiffer struts, springs, and larger sway bars than the SVT.
Personally, I prefer the ride that the SVT provides, especially at speeds above 80 MPH.
#504663 12/20/02 05:31 AM
SE rear sway bar is larger than SVT (1mm), SVT front sway bar is smaller though (4mm?) and thus should still handle better than a SE.
#504664 12/20/02 07:05 AM
WOW, 1mm !
#504665 12/20/02 07:21 AM
Originally posted by Rogerm60:
WOW, 1mm !
yeah, that's what i think, especially since my svt bar was $25 shipped, why would i spend more money for a SE bar just for 1mm.
#504666 12/20/02 06:22 PM
I
I
If you haven't replaced the struts, they're probably worn and the biggest contributor to bad handling. Does the nose pull down under braking, and jump up under acceleration? Changing struts will make the biggest difference. Then, if you want to improve from there, you can move on to the other things
contours, deloreans & fiats, oh my!
#504667 12/23/02 05:27 AM
Actually the engineering equation for the torion of a bar puts the diameter of the bar to the 4th power, thus making the diameter a hugely important factor. This is why 1 mm can and will make a difference in the stiffness of the sway bar. Oh and I believe that the stiffer springs the SE's had (20KN-m versus 18KN-m i think) is the real reason it handled "better" that the SVT he drove.
#504668 12/23/02 04:15 PM
N
N
He's most likely got a E0, since they changed the shocks on E1's to be firmer then the 98's and 95-97's.
2002 BMW M5 Carbon Black on Black 1998 Frost Silver SVT E0 17" Masitaly rims with Bridgestone Fuzion ZRi rubber. 133,000km 1996 Silver Ford Taurus SHO ATX 180,000km - SOLD! 1996 Midnight Red SE MTX 295,000km and a little squeeky.
#504669 12/24/02 02:36 AM
and the SVT has a 4mm (i think) smaller front sway bar, once again, putting it on top in the handling department.
