#5030 03/15/02 01:56 PM
My reverse lights don't work, I checked the bulbs and they are not blow nor is the fuse. People tell me it could be the switch on the transmission(auto)What are your thoughts?
1996 Contour LX----Fully Loaded Sony Xplod 650X 52Wx4 HU
Pioneer TS-A6865 in doors
Goodyear Eagle HP Tires All Around
Hanging Black Dice
Bocsh+2 DoublePlatnium Spark Plugs Red Spark Plug Wires
EBC Greenstuff Brakes
EBC Sport Groved Rotors
#5031 03/15/02 06:36 PM
In some cars I have drove, you do have to play with the shifter a little to get the reverse lights to come on. But other than that, check your wiring too, maybe something disconnected or fried. Just a thought.
~*TJ*~ 97 GL Sport Zetec
~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
#5032 03/15/02 10:14 PM
N
N
Yep, the switch is called a neutral saftey swicth. That is what I would think is the culprit.
#5033 03/16/02 03:15 AM
i tried moving it around and it doesn't work. I went to the ford dealer and they said it could be one of two switchs. That neutrel safety swtich and some other one.
Hanging Black Dice
#5034 03/16/02 05:15 AM
do a search for "reverse" in the Problems forum by member #243 (me). you'll find all the info you need.
1998 E0 SVT #3128, T-Red
2001 Infiniti G20t
1974.5 MG B GT
#5035 03/16/02 05:14 PM
It might also be due to installing a b&m shortthrow shifter and loosened something have you done this?
99 T-RED SVT
50,555 Miles and counting as off 7/12/2002
born jan 99
UR underdrive pulley
A Pillar Guages w/ AIR/FUEL VOLTS OIL PRESSURE "how to" members.aol.com/samplewon/apillarguageinstall.jpg
B&M short throw shifter
Eibach Springs
BAT Sturts
White Faced HVAC
2 ALPINE TYPE R 12" and ALPINE 1507 V12 AMP
Cup Holder Upgrade
PIAA super white Lows
Whelen 90watt 6 bulb strobe kit
Front end motor mounts
Mods waiting for install
3L(job has alrady begun, 3L totaly stripped.)
Quaife LSD
Apexi s-afc
Mirko splitter
#5036 03/16/02 10:16 PM
Check the wiring in the trunk..specifically where it enters the left trunk lid support arm. Stress point at this area where the wire (purple?)is flexed on opening and closing, and wire may break due to metal fatigue.cheap fix is a MAR connector and some electrical tape
That's what happened to my 95.
Let me know.
stock 95 LX,6cyl ATX
#5037 03/18/02 02:58 AM
well the wire is wraped in electrical tape but i put the car in reverse and moved the wire around and nothing. I think it is the neutral safty switch
Hanging Black Dice
#5038 03/18/02 04:45 AM
u check the fuses?
Black 98 Contour SE Zetec ATX
5% Charcoal-black tint (tint on exterior and interior)
Knauberized on 5-05-02
#5039 03/18/02 12:24 PM
did you ready my orginal post
Hanging Black Dice
