#50357 12/26/01 10:23 PM
Sam.S Offline OP
Hi i am trying to remeber the name of a spray that you use to check to see if you have an intake manifold leak. you start the car and let it run and then spray it near the intake and see if the eng runs the same or faster does anyone know what the name of this stuff is? Thanks for your help in addvance
Sam
#50358 12/26/01 10:31 PM
'Carb cleaner'......
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#50359 12/27/01 02:03 PM
Sam.S Offline OP
carb cleaner? I thought it was something that was made to do this job to locate leaks in the intake ? but if carb cleaner it is then so be it thanks for the help and information Terry i didn't think i could use that Have a gear and safe New year
#50360 12/27/01 02:11 PM
Only spray one small suspect leak area at a time, if the engine revs go up a little you have found the area of the vac leak...Happy new Year...
V6 MTX
#50361 12/31/01 12:43 PM
Sam.S Offline OP
Thanks Terry i will do this after all the snow melts lol and Happy New Year to yoyu as well and everyone in the forum have a safe and happy one
Sam
