Page 1 of 3 1 2 3
#502877 12/17/02 07:49 AM
W
W
what can i do to improve my idle to 3000 performance i have an intake already on and am getting my exaust put on next week, and i have an eltronic shift kit installed on it. when i am taking off from a light usually against tegs' they mop the floor with me i start catching back up with them but the damage is already done i cant quite regain my loss. My tranny chirps second prettty good (being an automatic and all), right now with christmas and all i cannot afford a chip, any tips please help the disgrace i am giving to contours by letting imports get me off the line. 95 contour 2.5 duratec
Wickedfantasies 95 contour 2.5 duratec LX
#502878 12/17/02 08:10 AM
F
F
Manual transmission, 3.0 Liter engine, 3000RPM stall converter... depending on how much $$$ you want to spend.
2003 Mustang GT 5-Speed, FMS 4.10 gears, Dr. Gas O/R X-pipe, Flowmaster cat-back, BBK CAI, C&L intake plenum, Accufab 75mm TB, Steeda Timing Adjuster - 13.70@102.23 (SOLD) 2000 Cougar V6 ATX with many mods - 15.93@86.97
#502879 12/17/02 08:11 AM
W
W
like i stated its christmas and i am now low on funds but thanks for the post approximately whats the cost for that
#502880 12/17/02 08:32 AM
Y-pipe
Chip
Exhaust
Intake
#502881 12/17/02 09:26 AM
Make sure your IMRC is working.
#502882 12/17/02 01:40 PM
-Pull and clean your UIM/LIM/TB. While its off, optimize your TB and LIM (Counter sunk screws and all). If you're really bored, gasket match your UIM to your LIM.
-New set of spark plugs.
-SHO Y pipe.
-Cold air set-up for your intake.
-If your new exhaust retains the resonator and rear muffler, you'll keep the <3000rom power. The more free-flow your exhaust is..the further up the powerband your TQ will travel.
Those are some cheap and easy mods you can do over the Holidays.
#502883 12/19/02 08:53 PM
Sandman used to really hype-up cracking the secondaries. I know that if you do this your secondaries will open at 1500rpm giving you that little boost earlier than 3800rpm when they normally open up. It doesn't cost anything... except for the added gas expense becuase it uses a lot more gas and will kill your miles per gallon.
99 SE Sport SilverFrost MTX 01 F4i Red/White My mom says I shouldn't talk to conservatives.
#502884 12/19/02 09:18 PM
Cracking the sencondaries will not change the RPM (determined by the computer) where they open up. You'll just get a little bit of air past them when they are 'closed'. Some folks actually loose some low end by doing this, so it's best to experiment with different settings to see which works best for your tour. I noticed some nice low end gains from optimizing the MAF and flex honing / polishing the UIM. Both of these are really cheap and make a very noticable difference. PM me if you want details on how to do either one.
#502885 12/19/02 11:03 PM
2
flex honing??
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
#502886 12/20/02 02:53 AM
Brake torque at 4k? Tried that yet?
Page 1 of 3 1 2 3
