#50278 12/24/01 06:40 PM
Is it passible to by pass that thing?
#50279 12/24/01 08:15 PM
Eh.....why????
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#50280 12/24/01 08:17 PM
F
F
Sure is. Get MIL eliminators. Dummies out the computer to make it think the O2 sensors are working properly, even if they are sending a bad signal.
http://shop.store.yahoo.com/mustangweekly/lmr-44.html
Nick F.
01 Focus ZX3 MTX
borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec
Yes its a zetec, we were here before vtec, so we are not copying!
#50281 12/24/01 08:19 PM
Only on post cat 02/OBDII cars, touch the pre cat and you screw up the mixture....
V6 MTX
#50282 12/24/01 10:00 PM
Like Terry, I would like to know what you are trying to do.
The O2 sensors work by generating a very small voltage in the absense of oxygen. Maximum voltage is 1.0 volts. Anything less than 0.5 volts is considered a lean mixture and anything over 0.5 volts is considered a rich mixture. In actual use, the voltage is constantly switching, not holding steady. These instant readings provide information to the processor to control fuel mixture. It is called a closed loop feedback system. Since the car was designed this way, there is no easy way to do away with the oxygen sensor.
Jim Johnson
98 SVT
