Page 2 of 2 1 2
#502443 12/23/02 08:19 PM
it shows a picture of what the upper and lower control arms look like in drawing form within a coil suspension system. Just check under struts
http://www.monroe.com/whatstdo.htm
There you will locate the upper control arm. Though in this picture it seems that only the lower control arm is used in a strut suspension system.
#502444 12/25/02 08:06 PM
Theres something called 'BANDWIDTH' and you just wasted a ton of it. In Fact this topic had nothing pertaining to that stupidly long A** post. What you should do is edit that damn thing with an Apology.......
PERFORMANCE PARTS for the TOUR click here:PXRACING Homepage email:pxracing@aol.com
#502445 12/26/02 04:00 PM
Actually, there's some really good information on that post. It takes a while to read, but I learned a lot from it, and that's why I keep coming to this site, to gather information. I may be wrong, but I figure a lot of the photos that are posted on here eat up a lot more bandwidth than does a long column of text.
#502446 12/26/02 05:54 PM
wattspxr said:
"Theres something called 'BANDWIDTH' and ..............'
I am at 765k how about you hope not 14k
#502447 12/30/02 05:14 AM
Dude, it has absolutely nothing to do with what Tony asked. He asked whether he has the earlier style lower a-arm with horizontal bushings, or the later style lower a-arm with the vertical bushings. I guess you don't know this, Contours have two different type of lower a-arm, the ones with the horizontal bushings are the older style used on the older (like pre-98 and some 98) Contours, and the ones with vertical bushings are the newer style used on newer (98+) Contours. That, my friend, has nothing to do with other fundamental lower a-arm design's picture. He wants to know what type he has because the two different lower a-arms are not interchangable because of the differences in the subframe. BTW, that post was way too damn long, it took me a good while to scroll through a bunch of stuff that I know was not related to Tony's question after reading the first paragraph. It's as long as me copy and paste my whole 3L FAQ in one single post.
Back on topic, here is a picture somewhat showing the lower a-arm with horizontal bushings:
Page 2 of 2 1 2
