Posts: 594 |
I was looking through the archives and found only one mention of this. On a 95 COntour SE w/ 2.5 L and MTX recently has had the engine light come on while running down the highway. The mileage is around 70,000 when this started to happen. Often it is when climbing a slight grade. I have a feeling it is a stuck fuel injector. The light doesn't come on as much after stepping up to 89 for fuel and have the injectors cleaned by Ford. Anyone have any ideas?
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 109 |
Mine was doing that...dealer looked at it while it was in for a recall repair and found that a hose had split and was sucking in fresh air. I'll try to remember to find the service report and let you know for sure, but I want to say it was a hose for either PCV or EGR, and it was something that (allegedly) ran a good ways around the engine. I got nicked $180 or so for repairing it.
Posts: 2,915 |
hey this doesnt pertain to your problem, but come join us in the ct forums..... http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=forum&f=45 i personal messaged you also  later corey
www.shox.com Dealer Koni's 135 a piece Eibach's 190 a set KYB's 70 a piece H+R's 225 a set see profile for website, aol name, etc Business:WestEndMobil@yahoo.com Personal:Corey_pimp1@yahoo.com 1998.5 SCSVT ($16000 takes it) 2001 GSXR-1000 1988 Corsica (the beater)
Posts: 2,915 |
also what town are you from, i have access to obd code readers, if you need one.....
let me know corey
Posts: 594 |
thanks for the reply, I am from Monroe, that is a bit of a drive from Winstead but I will keep that in mind.
My other thought my father had on the CEL was it had something to do with the exhaust gas recirculation system( is that what EGR is?) also the light would turn on then off then back on again, it seemed to cycle
Posts: 13 |
I had a problem with my '98 tour with the CEL coming on on the Highway as well. I had Ford look at it and they said was an o2 sensor, they said that the next 3 times after that then the mechanic ordered a new computer and the new comp started to report a small $15 part (can't remember the name) but what tipped the mechanic off was the the forward bank of cylinders had nice normal brown covered spark plugs but the rear bank was black excrusted (running rich) so if you don't have a code reader or if it tells you that it is an o2 sensor then check the plugs as well.
This may have nothing to do with your problem but I always like to share different possibilities.
Patrick
'98 V6 ATX GL Pacific Green Contour '96 4C ATX GL Performance White Contour '93 V8 351 F150.5 '68 Fiat 850 Sport Spider (In Peices)
