Posts: 834 |
hey guys i just got an intake (weapon R). I wanted to know when i put it on(the new intake) what do i do with the sensor that was located orginally on the stock intake? thanks
lucas
HaHa You Watching me? Keep Watching
Posts: 110 |
There should be a hole in the intake with a rubber gromet. I stuck mine in there. If that's the sensor you're talking about.
1997
Thunderbird LX
Clairion HU, sub and amp
In the works:
true duals, headers, cobra MAF
In the works: Mustang with a big block
Posts: 834 |
no this intake does not have a hole? that why i wonder what to do with it?
Posts: 21,653 |
make a hole
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 35 |
I have the same problem. I have a K&N filter with the MAF adapter from BAT. Well What the hell do I do with the sensor that was in the stock air box? BAT sold me that tube with the spliter...what am I supposed to do with that?  It would be better served to use it to drain my brake fluid! Buy the way I plan on calling BAT soon to get the answer for this.
95 GL Duratec ATX Loaded!
Posts: 9,065 |
I think you're talking about your IAT! I can't remember what the Weapon R exactly looks like, but the silver intake tube thats replacing the accordian should have a hole for it, if not you'll need to drill into it and find a way to seal it so you don't suck air in through that new hole.
Posts: 10,015 |
If you have no hole already, then the best thing to do is make a small hole in the rubber base of the filter that is smaller the the diameter of the sensor, nd then push the IAT sensor into that hole (make sure it is snug). That way it's in the airflow, and you don't have to really drill anything metallic etc.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,653 |
i think nos got just a filter, not a complete intake, that's why he has no hole.
98.5 SVT
Posts: 10,015 |
Well he can install the IAT snesor as I suggested then without any problems.
AUSSIE ENDLINKS $70
Posts: 331 |
The kit does work I installed on mine with the KKM and BAT pipe.
