Page 3 of 6 1 2 3 4 5 6
#498759 01/16/03 07:57 PM
true or false:
A lighten flywheel puts less strain on the crank, thus helping the DMD do its job better, or possible eliminate the aftermarket DMD all together?
Roz
#498760 01/16/03 08:00 PM
I would say that it would put less strain on the crank due to the fact that there is a lower moment of inertia on the crank due to the lighter flywheel, thus the amount of twist is reduced. The DMD shouldn't and wouldn't be eliminated. I would recommend that it be fitted, every time.
#498761 01/16/03 09:22 PM
I wans't in particular talking about elminating it all together....what i ment is what if you didn't replace the stock DMD with the European one from the Mondeo, would you need to still having replaced the flywheel?
Sorry, i probably didn;t make myself clear.
Roz
#498762 01/16/03 09:25 PM
The stock pulley dampener is NOT a Dual Mode one, anly single mode. So regardless of what flywheel you have. You should fit one of these for peace of mind.
#498763 01/16/03 09:32 PM
Thank you very much for the answer. Any news of where i can get one. When I checked a week ago, SP,and BAT said there still wasn't enough for the demand.
Roz
#498764 01/17/03 01:29 PM
Onw what? DMD or Flywheel.
DMD's are available form Terry Haines secondline@ameritech.net
#498765 01/18/03 06:50 AM
Q
Q
Seeing as I was dropping my trans to add the Quaife and Zetec final drive (in preparation for the Turbo), it was brain damage NOT to add the Fidanza and Centerforce DF clutch.
I want ALL the power I can get to the ground!
dido seeing as though my clutch went out. thinking ahead for the turbo i went with the cf dual friction. since i dont have brain damage i too went with the fidanza flywheel. its no sense on taking the tranny out twice , once for the flywheel and then the clutch. while all thats out ill be going with a quaife, zetec final drive, basically rebuild from terry haines. why make more work for your self.
2000 t-red SVT ****too quick for civics**** i have a few tricks up my sleeve
#498766 01/18/03 03:07 PM
W
W
Sounds like a good plan! I personally don't think that there is a significant reliability issue with the fidanza, especially considering the number of successful users out there. I just wanted to point out that there was some basis for its consideration. When I beef up the trans I will certainly entertain adding one though I am still not convinced I will really miss it. I considered that when I had the motor out for the 3L swap in Dec 01, but costs were already too high and I decided I would wait until I could afford to do the whole trans.
warmonger
#498767 01/18/03 03:19 PM
W
W
With regard to a lighter flywheel putting less strain on the crank:
How does the small change in twist/strain due to changing the flywheel compare to the amount of strain generated by the simple act of engaging the clutch and moving a 3000# car?
I mean yeah, there is a change but so what when dumping the clutch on a fast take-off is what the engine is designed to do and must generate a tremendously higher amount of strain.
So I ask is this truly worth consideration? It's like telling someone that the distance to their house is 4.54781 miles!
Lighter mass = more acceleration to the wheel and quicker rev's are the only benefits worth mentioning I think.
warmonger
#498768 01/18/03 07:31 PM
Q
Q
warmonger
and if you ask me i think thats what fidanza desighned the damn thing for. ohh but thats my $.02
