Page 1 of 3 1 2 3
#498469 12/10/02 08:11 PM
When I start off from a start with more than 50% throttle i get a stutter. Fuel filter is good , air filter is good, plugs and wires are good, no CE light? any ideas?
98 Contour SE Zetec ATX Chevy Corsicas Fear me! 100K and still going strong!
#498470 12/10/02 08:16 PM
Similar problem here. I'm getting pissed and will soon go on a buying spree to fix the problem. Potential replacement items are: mass air sensor, TPS, fuel pump and coil.
Also heard it could be vacuum-related, but haven't found anything yet.
How many Vs would a VTEC TEC if a VTEC could TEC Vs? The one, the only....FRNKNFORD http://www.westvalleycs.com
#498471 12/10/02 08:48 PM
sounds like the plug wires, does the car idle fine?
if it idles fine then it was the same problem I had and the plug wires went bad, I thought they were fine but after 108k or so they wern't good anymore
#498472 12/10/02 08:56 PM
I replaced mine and still have the problem. I've also replaced the plugs (twice) and super-cleaned the fuel system.
#498473 12/11/02 12:05 AM
Z
Z
Have you cleaned the MAF yet?
'97 Mercury Mystique GS (Not mine anymore...) Now running a Toyota Matrix XR Red, 16" wheels, Sunroof, VVT-i
#498474 12/11/02 12:07 AM
I cleaned my MAF, yes.
#498475 12/11/02 01:01 AM
Why are you starting it at over half throttle anyway?
#498476 12/11/02 04:37 AM
TTT
Possible causes:
Plugged cat - affects top end too.
TPS
Insufficent spark / wrong gap. (plugs, wires, coils)
Leak between MAF and TB (gets worse as pressure in intake pipe falls)
Fuel pressure falls (filter, pump, regulator)
MAF sluggish
Spark problems give rough stutter, the others are more like a big loss of power.
#498477 12/11/02 06:12 AM
CEG road warrior
CEG road warrior
Originally posted by Rogerm60:
TTT
Possible causes:
TPS
MAF sluggish
When I had a leak between the MAF and the TB the car didn't even run.
#498478 12/11/02 06:59 AM
I just mean a leak, like the crankcase fresh air hose being off.
Page 1 of 3 1 2 3
Moderated by  Loco4G63
