Posts: 35 |
When I start off from a start with more than 50% throttle i get a stutter. Fuel filter is good , air filter is good, plugs and wires are good, no CE light? any ideas?
98 Contour SE Zetec ATX
Chevy Corsicas Fear me!
100K and still going strong!
Posts: 2,291 |
Originally posted by TomServo98: When I start off from a start with more than 50% throttle i get a stutter. Fuel filter is good , air filter is good, plugs and wires are good, no CE light? any ideas?
Similar problem here. I'm getting pissed and will soon go on a buying spree to fix the problem. Potential replacement items are: mass air sensor, TPS, fuel pump and coil. Also heard it could be vacuum-related, but haven't found anything yet.
Posts: 6,910 |
sounds like the plug wires, does the car idle fine?
if it idles fine then it was the same problem I had and the plug wires went bad, I thought they were fine but after 108k or so they wern't good anymore
- 95 Mystique LS - Zetec/5spd
Posts: 2,291 |
I replaced mine and still have the problem. I've also replaced the plugs (twice) and super-cleaned the fuel system.
Posts: 237 |
Have you cleaned the MAF yet?
'97 Mercury Mystique GS (Not mine anymore...)
Now running a Toyota Matrix XR
Red, 16" wheels, Sunroof, VVT-i
Posts: 2,291 |
Posts: 682 |
Why are you starting it at over half throttle anyway?
Posts: 2,408 |
TTT
Possible causes:
Plugged cat - affects top end too. TPS Insufficent spark / wrong gap. (plugs, wires, coils) Leak between MAF and TB (gets worse as pressure in intake pipe falls) Fuel pressure falls (filter, pump, regulator) MAF sluggish
Spark problems give rough stutter, the others are more like a big loss of power.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by Rogerm60: TTT
Possible causes:
When I had a leak between the MAF and the TB the car didn't even run.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 2,408 |
Originally posted by Hector: When I had a leak between the MAF and the TB the car didn't even run.
I just mean a leak, like the crankcase fresh air hose being off.
