The intake system offered on EBay appears to be of very good quality. The problem is when the time comes to install it. The MAF adapter is about 3/8" undersized. The holes don't line up. The intake tube is too small also. This shouldn't be an intake kit to consider for our cars. I'm sure this point has been brought up before. Being the sceptic, I had to find out for myself.
Black '99 Contour SE Sport S-AFC II | 7" S&B Filter w/Cold Air Box | Ford Racing Wires Yo-Dude wye & Exhaust | Konis | Roush Springs | DMD F&R Strut Tower Braces | BAT 21mm Rear Torsion Bar Poly Bushings | Alum. Dbl. Wing | SP Powerset
id file negative feedback with him.
Exactly!!! I had the same problem with that thing, a bunch of guys here said they didn't have problems, but whatever, mine sucked. Biggest waste of $90 I ever spent on a car.
1998 Silver Frost CSVT #4014 Some mods My car
honestly mine fit fine.
99 Mystique LS T-Red ATX Duratec Mods: Hella stereo Mods K & N air filter w/intake pipe www.sounddomain.com/id/jongordo8
yeah they were kinda tight fit mine didnt fit so i jsut kinda made it work the best i could, also mine had 3 nipples one side and one on teh other, shouldnt it have been 2and2. also my o2 sensor didnt protrude into the airflow so i stuck it in a piece of tubing and then stuck teh other end of the tubing over one of the nipples. kinda real rigged. also what does that piece of flat metal go to. i never used mine.
1999 SVT #336 Tropic Green 19" Axis Se7ens INJEN intake OMP Strut Brace HPP Rear Brace B&G Drop www.cardomain.com/id/svtpyr8
BDR Offline
i bought one and put it on with a Pro Flow 75mm MAF and it works perfect!
the holes were a little off on mine too, but once i put it together it looked and worked perfect. to me it was $90 well spent!
2000 CSVT (SOLD) #531/2150 now 2003 WRX !FINALLY SPONSORED! "Big Pimpin, Never Slippin"
The ID at the filter side of my MAF is 80mm. The ID of the MAF adapter is 74mm. Are you guys telling me that your MAFs are 74mm at the filter side? Or is the adapter that you got 80mm ID?
I'M SORRY. SOMETIMES E-BAY BITES.
a D*CK SLAP IN THE FACE IS ALL I GET FOR STICKING MY NECK OUT FOR A FORD... PLEASE DELETE MY ACCOUNT!
I was one of the first to buy one oef these, and everything worked fine, sorry to hear you had probs.
1998 Black 3L Contour SVT Sweet Home Alabama
