CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 21,653 |
Originally posted by Hector: I have been doing and it has been pretty easy. Well not really but I would like to think it so I don't get pissed off at the car and get rid of it.
your an inspiration to all us frustrated zetecers,, can count how many times i thought of trading for an old mr2 or 280sx/zx,,, or even a zx2.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
CEG road warrior
CEG road warrior
Posts: 17,248 |
Hector
257HP/259TQ
160HP/141TQ
Posts: 76 |
The kit was set up for a zetec... headers, bellhousing adapter, exit hole for the header, mount kit. The size of the zetec. The other alternative would be the pinto xflow. The hydro zetec is ok for mods, but the aftermarket is weak in the US for the contour platform.. Crane were not interested in grinding cams for me...No market. The focus platform on the other hand has a lot more aftermarket interest.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by se7en: The kit was set up for a zetec... headers, bellhousing adapter, exit hole for the header, mount kit. The size of the zetec. The other alternative would be the pinto xflow. The hydro zetec is ok for mods, but the aftermarket is weak in the US for the contour platform.. Crane were not interested in grinding cams for me...No market. The focus platform on the other hand has a lot more aftermarket interest.
Get a set of Crower cams (Focus)
Hector
257HP/259TQ
160HP/141TQ
Posts: 76 |
Hector, I'd have to convert to mechanical lifters, valves and pistons. I should have a Kent cam kit on the way from Burtonpower. When I was sourcing a Zetec for this kit, I could not find a ZX3(focus), but I came across several ZX2 (escort).I was advised to stay away from the ZX2 becuse the waterpump is offset on the block. There is very little room towards the nose on a seven. The Contour is the easiest Zetec to fit.
Posts: 2,023 |
Too bad you could not just fit a turbo setup under there and not have to worry about all this N/A stuff.
-Giovanni
One turbocharger. Two intercoolers. All love.
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by se7en: Hector, I'd have to convert to mechanical lifters, valves and pistons. I should have a Kent cam kit on the way from Burtonpower. When I was sourcing a Zetec for this kit, I could not find a ZX3(focus), but I came across several ZX2 (escort).I was advised to stay away from the ZX2 becuse the waterpump is offset on the block. There is very little room towards the nose on a seven. The Contour is the easiest Zetec to fit.
That is interesting. The 98+ (like mine) have the Zetec VCT; the same as the one in the ZX2.
Hector
257HP/259TQ
160HP/141TQ
Posts: 76 |
Hector, I should specify 97 and older Contour Zetec. Ausgedient, The thing is already a cheek clencher.
