Posts: 6,910 |
Originally posted by Kremithefrog: my zetec doesn't burn in any oil.
my parents cars don't burn oil either
- 95 Mystique LS - Zetec/5spd
Posts: 1,020 |
Mine doesn't burn any noticable amount. Stays on the same place on the dipstick. I've got a really small front seal leak as well. That is with 65K miles and 15K of those with the vortech.
Posts: 317 |
I probably use half to a quarter quart of oil between oil changes and my car has 57,000 miles. Do you use synthetic or regular oil?
99 red svt
Originally posted by LUCA: Yep.
You can be Phil too if you'd like.
Posts: 1,020 |
Mobil 1 and Royal Purple since first oil change
Posts: 9,602 |
I know I drain nearly 1/2 a quart (cumulatively) from my oil seperator in the time between oil changes. Otherwise it would all go down the intakes!!!  I do notice the the more I get on the engine (I.E. higher rpms) the more oil in the seperator. Which of course makes sense, but I stated it just for reference.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 4,693 |
Zip. Oil level on dipstick does not go down between oil changes every 3000 miles. I use 5W30 Mobil dino oil. I just hit 150,000 miles.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 30 |
Originally posted by 99 red SVT: I probably use half to a quarter quart of oil between oil changes and my car has 57,000 miles. Do you use synthetic or regular oil?
99 red svt
I've used Mobil 1 since the first oil change.
Posts: 9,602 |
Originally posted by Black EO: I've used Mobil 1 since the first oil change.
If you bought the car new then that is likely why you have an oil consumption problem. Switching to synthetic oil that quickly did not let the rings seat properly and therefore you are getting excessive blow-by (loss of performance, mileage, longevity and high oil consumption) The manual even states waiting for 4500-6000 miles before changing to synthetic.
2000 SVT #674
Posts: 30 |
Originally posted by DemonSVT: Originally posted by Black EO: I've used Mobil 1 since the first oil change.
I don't know. With so many cars coming from the factory with a synthetic factory fill...I'm not sure I believe that anymore. BTW...your owner's manual said to wait 4500-6000 miles? Mine (from '98) didn't mention any specific interval for a switch to synthetic.
Posts: 9,602 |
Originally posted by Black EO: 1. I don't know. With so many cars coming from the factory with a synthetic factory fill...I'm not sure I believe that anymore.
2. BTW...your owner's manual said to wait 4500-6000 miles? Mine (from '98) didn't mention any specific interval for a switch to synthetic.
1. A handful of performance cars out of hundreds of models. Not "so" many! Cylinder honing/finish and ring composition determine seating time. If Ford recommends to wait for 4000-6000 miles (checked manual) then they probably have a good reason for it being as they know the engine honing method & finish and the rings used. 2. Yes it's in the SVT supplement. (page 13) Scanned pics have been posted multiple times in the past.
2000 SVT #674
