#4969 03/15/02 01:55 AM
E
Evil1 Offline OP
E
I have green underbody neons on my car and my ground effects are to short so the neon tube show were the ground effect curves up in between the front and back doors. Does anyone else have this problem. And if so how did you hide the neon tube if at all.
thanks
'98 Contour se V6 auto
Blue headlight,foglights, and green backup light and green underbody neon
Clarion Pro Audio headunit
6x8 Audiobahn up front
6x8 Infinity Kappa in rear
all new system coming soon
slimshorty42@hotmail.com
#4970 03/15/02 02:28 AM
E
E
SVT side skirts maybe?
When I had mine om my car I put them inside the bottom lip and they were fine(never seen). I just took them out for winter.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
#4971 03/15/02 02:44 AM
E
Evil1 Offline OP
E
mine with not fit inside the bottom lip that is the problem that I have and I want the SVT skits but I also might get the new bodykit that the are having made.
#4972 03/15/02 07:56 AM
here's a quick fix....remove the neons from the underside of the car....put them back in the package and return to whereever u got them... wink
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
