Posts: 9,602 |
Originally posted by skid123: Originally posted by SVTMike: Plus they dont corner for crap!
so true. I considered buying one before the SVTC but they were only available in atx, horrid handling, and they're so common. I didn't find it too hard to sacrifice .5 second in the 1/4 and get the Contour.
Exact same thing here! I test drove one just to satisfy my curiousity when I was looking for a new car. I hated it! Floaty, boat like handling with no feel of the road and no control of the gears since it's a slushbox. Yes the old Buick engine makes some decent power, but the many other downfalls vastly overcome that. Then there's the tacky cheap plastic interior.  It's definitely not a driver's car! Hence why I bought the SVT. It is a driver's car.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,173 |
So the GTPs really aren't that much faster than SVTs eh? Interesting...I was also considering one as my next car for a while...but after hearing you guys say they handle like crap, I couldn't take one...my motto is what's the point in having the power if you can't corner with it??? Sounds like a signature quote...
-Brian
2002 Jaguar X-Type 3.0 ATX - British Racing Green (two-tone) - 44,000+ miles
Former owner of a black '99 SE Sport Duratec ATX - 107,000+ miles
CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by beyondloadedSE: i think the fastest gtp runs like an 11.9.
11.7, seen it first hand. Stock GTP is high 14's Moderately modded is 13's
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,977 |
I'm actually interested in one, the new GTP Comp G or whatever it is. The one that has 270HP and has pad shifter.
Posts: 327 |
I have a 94 gtp for the winter. You guys are right! It dosen't turn it slides  But hey, its fun as He11 to beat on  Plus I like the heads up display
Posts: 568 |
Originally posted by AirKnight: The one that has 270HP and has pad shifter.
You mean the glorified 4T65-E, heat-generating fluid-coupling slushbox, right? The Hydra-matic's a good slushbox, but a slushbox it is. Next, please...
B. Riley
Melbourne, FL
'01 Camry LE V6/5-spd
Was: '00 Black/Tan SVT Contour #560 - Sold 3/26/03
Before that: '95 Champ/Blue Contour GL V6 ATX
Posts: 1,580 |
If the GTP you're referring to with the "ricer" wing on it is red with a checkered flag graphic on the side, it is not stock by any means. It is owned by Zoom, who is also the owner of ZZPerformance in Grand Rapids. And yes he is running 11's. (fastest one in the nation)
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 2,091 |
A friend of mine bought a 2001 back in June...since then we've put Koni's with eibach springs, larger swaybars front & back, poly bushings, and strut tower braces front & back. Total cost $1050. It's a completely different car now. No body roll at all & it feels 500 pounds lighter. We weren't going to put the larger front bar on, but stock it had the tendancy to oversteer a bit and my friend didn't feel comfortable with that, so we put the larger front bar on it's damn near perfectly neutral now. I'd say it handles at least 2x better than my 96 SE.
Posts: 1,469 |
I think its true that suspension mods can make any car handle decent, even SUVs. But, doing the same degree of suspension work to a Contour would put it back ahead by the same margin...better chassis, better steering, and 500 lbs less weight than GTP cannot be easily overcome. And you still got that damn ATX and no LSD availability.
1999 Amazon Green SVT Contour (#554/2760)
"People demand freedom of speech as a compensation for the freedom of thought which they seldom use."
-Soren Kierkegaard (as posted by Jato)
Posts: 2,091 |
FYI there is a quaife now available for the GTP.
