Posts: 1 |
I have had my 98 Contour in the shop all week now to get the timing belt changed. The new belt snapped almost immediatly, so the repair place changed the pulleys. The belt then shredded again, so the repair place looked deeper and found the cam assist mechanism wasn't functioning properly. After several conversations with Ford motor company, it was determined that this must be a factory problem. Adding to this is the fact that one Mercury dealer in town had a kit to fix this problem, including a new solenoid. Very curious. Anyone have a problem like this or any suggestions?? A thousand bucks is a huge bite, so Ford will fix this for free if this is there problem.
Thanks!
Posts: 36 |
Can you post info about the "Fix kit" ? Thanks,
jim
Posts: 2,794 |
2.5L with a timing belt? I guess I am confused here....
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 123 |
Zetec uses a timing belt.
Duratec uses a timing chain.
2000 SVT #669 Wimpy Stock stuff
Posts: 2,794 |
I miread his post, thoughtr I saw the V-6 in there somewhere (gotta lay off the crack)
Posts: 56 |
your vct went bad,everyday thing to see on a zetec at my dealer.never heard of it causing the timimg belt to break
Posts: 2 |
Kenny,
What is a "VCT"?
I have a 1996 Contour 4 cyl. with 60k miles. It is in the shop for a loud timing belt noise. Any idea what the problem is?
Greg
Posts: 594 |
If what you mean by a timing belt noice is a tapping noice then it is the belt hitting the cover. My car dos this on colder days. My car has 96 thousand on it and is still running great but I plan to change the timing balt soon, from what I have read it happens to some people and not others, nothing to worry about unless it happens all the time
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 156 |
VCT's go bad????
OH NOOOOOOOOOOOO!!!!!
And here I sit laughing at you losers who have to deal with EGR valves!!!!
Oh well.
No, those of you who have pre -98 Zetecs don't have VCT, you have EGR's. EGR's suck because they have to be cleaned after a while, yet the VCT thing should last forever. Apparently, it does not.
VCT was a short lived thing, and is sporadic. There is no rhyme or reason as to which car gets it and which does not. I used to think there was, until I found that the newer Black valve cover Zetecs are sometimes VCT equipped.
It's a mess...
RAndy
