Page 2 of 2 1 2
#49647 12/25/01 03:44 PM
Thanks again!
#49648 12/31/01 09:08 PM
Sorry just one more question. If the car is parked and you gave it gas, would the IMRC engage and the secondaries open up, or do you have to be driving the car for the IMRC to engage?
#49649 12/31/01 09:34 PM
I
I
I had to replace my IMRC. I bought a new one from Ford Outlet .
It was easy to replace. Make sure you buy the $5 grommet.
98 Contour LX V6 Mtx
#49650 01/01/02 01:14 AM
BBContourSVT,
While revving the engine in park,
Quickly snap the throttle open.
As the revs drop down, you will see the secondary valves open and close momentarily.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#49651 01/05/02 08:45 PM
Can the IMRC be bad and not trigger a CEL? Example:IMRC recieves sigal from PCM but motor doesnt turn. One more thing, if the imrc doesn't open one time and triggers a CEL and the next time it does open will the code be "erased" and the CEL will turn off? Thanks
#49652 01/05/02 08:55 PM
IMRC's are a b!tch..
Atleast yours is a physical problem that can be seen. Mine turned out to be a shorted wire.
I believe this was a major problem back in the day with the IMRC... I think Ford did a recall on it or something, It happens when the wire rubs against the pulley that is under the cover.
Glad you know what it is already and should be able to fix it quickly.
About your questions.. Not really sure. If your IMRC doesnt open once, I dont think it will throw a CEL at all. If it happens more than once on seperate "key-on's" you should get a CEL. I know mine wouldnt throw a CEL on the first start after a reset of the ECU, but the next key on would.
Good Luck.
Jon - NJNeco
2000 Silver Frost Cougar v6 MTX
Dyno Tested 173.6 whp - 161.2 wtq
Visit MaStaMooN.Com for Details! *Back up in a limited form*
Page 2 of 2 1 2
