#49623 12/14/01 12:12 AM
F
fazzman Offline OP
F
I pulled a P0420 bank one yesterday on my zetec. Reset the computer and goes away until i have to sit in traffic after work. When i come to a stop after driving the car a lot the engine sometines stumbles, doesnt stall though. Other then that everything is ok. Im thinking bad rear O2 sensor, its all rusted up and evrything. Thanks
Nick F.
01 Focus ZX3 MTX
borla, eibach pro kit and dampers, dual guage pod (a/f and volt), jvc kd-sh99
96 Contour GL atx-zetec
Yes its a zetec, we were here before vtec, so we are not copying!
#49624 12/14/01 12:22 AM
it may be rusted up, but you said yourself that it said BANK 1 and that code IS for bank 1
the front header as you open up the hood is the bank 1 header....someone correct me if i am wrong
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
see profile for website, aol name, etc
Business:WestEndMobil@yahoo.com
Personal:Corey_pimp1@yahoo.com
1998.5 SCSVT ($16000 takes it)
2001 GSXR-1000
1988 Corsica (the beater)
#49625 12/14/01 01:16 AM
F
fazzman Offline OP
F
I do have a zetec. So i would have 2 banks? One for each O2 sensor?
Nick F.
01 Focus ZX3 MTX
#49626 12/14/01 03:11 AM
Nope, you have one bank with an upstream and a downstream sensor. Upstream -> before precat, downstream -> after precat and before main cat.
#49627 12/14/01 04:31 AM
oh my fault i wasnt even thinkin of a zetec, i was thinkin duratec, DUH.....
sorry smile
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
#49628 12/14/01 11:46 AM
F
fazzman Offline OP
F
It says below threshold? Isa that downstream?
Nick F.
01 Focus ZX3 MTX
#49629 12/14/01 04:30 PM
no below threshold, means like below a tolerance of the sensor......
the sensor is "sensing" that something isnt operating up to "spec"
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
#49630 12/14/01 10:42 PM
F
fazzman Offline OP
F
So in other word gut the CAT to fix it?
Nick F.
01 Focus ZX3 MTX
#49631 12/15/01 04:27 PM
im not sure whether thats your cat, or the sensor.....i've heard both stories
i have heard that it is the cat more though
im not really sure to give you the advice man......i dont want to give you the wrong info....maybe someone else will chime in with an answer for you
www.shox.com Dealer
Koni's 135 a piece
Eibach's 190 a set
KYB's 70 a piece
H+R's 225 a set
2001 GSXR-1000
#49632 12/16/01 07:06 AM
Gutting the cat will not fix it. Gutting the cat will cause a "below threshold" error code because the cat is not working effeciently.
The cat monitor is a program in the PCM on all OBD II cars that runs ocassionally to make sure that the cats are working properly. That is done with the rear O2 sensor. An O2 sensor normally is switching constantly from rich to lean. An O2 sensor mounted behind the cat switches very slowly or even almost not at all when the cat is working. When the cat has lost effeciency, the rear O2 sensor will switch nearly as rapidly as the front. When the front and rear are switching at or near the same rate, the cat monitor will recognize that the cat is "below threshold", set a code, and turn on the MIL.
Also, on a V6, bank one is the rear bank. Cylinders 1, 2, & 3 are bank one, and that is the rear bank. Cylinders 4, 5, & 6 are bank two, and that is the front bank. The numbering system goes back to rear wheel drive cars. Ford always numbered cylinder #1 as the right front. With the engine moved to the east-west position, the #1 cylinder is in the same place.
Jim Johnson
98 SVT
