#49548 12/13/01 08:32 PM
cspd302 Offline OP
Had my 00 SVT taken to Ford cause the tranny got stuck in either 1st or 2nd. Anyway they disassembled the tranny and found the forks to be the problem. Also they found out that all the motor mounts were broke. eek Anyone else hve these same problems? confused
2000 SVT contour Green w/tan
KKM filter w/ a lil SQUEEZE
14.4 @ 100 m.p.h
#49549 12/13/01 08:39 PM
This a common problem...I've seen afew transmissions with the same issue...
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#49550 12/13/01 08:49 PM
could this happen to an automatic transmission?
No car anymore ;\ (taking a break from driving due to several misfortunate occurances)
Newest mod for my Dad's Cobra 'vert: My beautiful girlfriend and I for passengers when we want to go somewhere laugh
#49551 12/13/01 08:51 PM
No, the selector forks are on MTX75's only...
V6 MTX
#49552 12/13/01 08:53 PM
cspd302 Offline OP
Is there anyway to prevent the problem again?
14.4 @ 100 m.p.h
#49553 12/13/01 09:17 PM
If you're bending the forks and breaking the motor mounts, I would recommend being a little more gentle with your car.
99 SVT Black/Tan #1090/2760
82K Miles.......B&M Edge Shifter
Mobil1 5-30.....Side Markers
Ford Synth MTX # XT-M5-QS
Locking Lugs....Cup Holders
Black Sail Panels...TH Fix
Aluminum Gas Filler Door
BS Potenza S-03's
KVR Cross Drilled Rotors + Pads
Dual Mode Damper - soon
Clarion head unit
Pioneer 2-ways
#49554 12/13/01 09:22 PM
cspd302 Offline OP
The only time I hammer the car is when I'm on the spray. I see other tours with the blower setup and wondering if they have had similar problems. Would the B&M shifter help out at all or just give me shorter throws? I'm a mustang guy so most shifters help the tranny, that's why I asked.
14.4 @ 100 m.p.h
#49555 12/13/01 10:01 PM
Only time is on Nitrous... :rolleyes:
That's worse on your drivetrain then anything else. It's "Instant On" power as in coming on all at once. Like hitting it with a big hammer!
S/C builds with rpm. So it's a gradually increase in power until you are moving and well into the power band and then it flies.
BTW - What nitrous setup are you using? And why are you dumping fuel & nitrous before the MAF? eek
2000 SVT #674 - Check it out!
#49556 12/13/01 10:15 PM
cspd302 Offline OP
It's comucar bottle in a bag. It's a dry system. They've had it for about 6-7 years now. It was mostly installed on the SC,GA,FL mustang patrol cars. When the N20 hits the hot wire in the MAF the computer reads it as ALOT of cold air, so it tells the injectors to dump more fuel. Very nice system. Very easy to install and is TOTALLY hidden. The car doesn't run lean. I do regular checkup's with the plugs and the all look fine. I have gone with 1 step colder though. Reason why I asked about the boosted guys was that the system makes over 80 hp. Am I correct? I'm only squeezin a 60 shot. It's only coming on after 3 grand, so everything is moving pretty good. Here's something else to ponder,if the car is completely stock minus the N20, what about the guys with all of the other mods?
14.4 @ 100 m.p.h
#49557 12/14/01 01:19 AM
this setup seems interesting..where can it be had?
1999 Silver Frost SVT
#609 of 2760
Born on 12/3/98
KKM Intake
Removed Resonator
35% Window Tint all around
Tinted Tail Lights
ElKy Mesh Grilles
HID
Dyno'ed at 175.3HP/155.5TQ
