#494255 12/04/02 09:19 PM
Dmitri Offline OP
What's up everybody?
I've got Ground Controls working with Konis. When I turn the steering wheel, left front spring moves but the aluminum top hat doesn't (they should be moving together) and it makes metal noise. Do any of you know the solution to this problem? Thanks. [image]http://www.ground-control.com[/image]
98 Black E0
#494256 12/04/02 09:27 PM
Not sure what you are referring to...maybe the bearings?
How long have the GC's been on?
When's the last time you greased them?
I was getting a "crunching"/metal grinding noise when I turned and found that the bearings were rusting.
Threw a little marine grease on there and no problems since.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#494257 12/04/02 10:07 PM
Dmitri Offline OP
Thanks a lot for the comments. It might be the case.
98 Black E0
