Ok, I have been having this problem for a while now. When I shift into second, sometimes the whole pattern moves. Neutral is where second, fourth, and reverse should be, and first, third, and fifth are where neutral should be. Second, fourth and reverse can't be reached because the shifter will not move that far back. I can remedy the problem by shoving the shifter into third gear and I can feel whatever is moving move back into the correct place. The dealership rebuilt the tranny because of a third gear grind and I mentioned this problem, but it was never fixed. I was hoping someone would recognize this problem so I could tell the dealership what needed to be fixed. My only other option seems to be to recreate the problem and deliver it to the dealership with neutral where 2nd, 4th, and reverse should be.
