#492934 12/03/02 10:06 AM
I have a knock coming frome my front driver side strut. When I turn the wheel I can see the mount move over in the tower when it knocks. I am runnung Konis with Roush springs. Any Ideas?
'98 Black/Blue CSVT -#162 D.O.B 4/12/97- -----Many MODS-----
#492935 12/03/02 07:06 PM
When I first replaced my front struts, I had a knock coming from the top of the strut. I tightened the nut on top of the strut, and the noise stopped. Guess I need to invest in a torque wrench.
#492936 12/08/02 12:13 AM
Its strange because i can see the strute move?
#492937 12/08/02 02:00 AM
Yeah, it freaked me out too when I first saw it move.
#492938 12/21/02 01:28 AM
Ok, I checked my strut its tight. I dont know where to go from there. Is there someone with advice?
#492939 12/21/02 02:07 AM
Are you sure it's your suspension?
I thought I had a front left suspension knock- turned out to be my K&N hitting the front wheel guard when going over bumps!
David. yr 2000 Mondeo ST24 V6 sedan Mondeo ST24 Information Site
#492940 12/21/02 03:07 AM
E
E
Does your retainer fit tight against the strut tower? When I installed new front struts, I tightened the top strut nut with the weight of the front end off the wheels. When I lowered the car, the retainer moved off the top of the strut tower, allowing the strut assembly to move, clunk on tight turns etc.
I assumed the lower nut of the stut assembly was a "Nyloc"
nut like the top strut nut. When I looked at my original lower strut nut I saw it was a regular low profile nut. You can not use a Nyloc nut to fasten the upper mount to the strut. When you try to tighten the retainer it will bottom out on the taller Nyloc nut and not allow the retainer to seat tightly to the tower.
