Believe "32" code means there is an open on the drivers side air bag circuit. Most likely that's a "clock spring" under the air bag. Remove the Two Torx screws holding the air bag in place and unsnap the clock spring. Using and ohm meter, check out the "spring". Do not use the meter on an air bag, it can deploy with very little voltage.
