#492168 12/02/02 05:41 AM
JAGSVT Offline OP
does anyone know what the creaking sound i keep hearing when i hit bumps in my svt could be caused by?
please don't tell me its from rust or something that icannot fix!
thanks,
jim
2000 SVT, #387 of 2150 Silver Frost
#492169 12/02/02 06:17 AM
Could be sway bar bushings. Try greasing them up with some marine grease and see what happens.
Capitol CEG Classifieds Make an offer! 2005 GTO IBM - 337hp/336tq
#492170 12/02/02 09:12 PM
Has this happened recently as the weather has turned colder? My 99 SVT has the same issue, but has only started doing it in the past week or 2 with temps in the 20's.
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
#492171 12/02/02 10:47 PM
I have a BAD creak coming from what sounds like my passenger side B-pillar, driving me ^&*# bug nuts!
#492172 12/03/02 04:44 AM
JAGSVT Offline OP
yeah, i was actually thinking today that it only seems to be noticeable in the early morning or at night when its been sitting cold for a long time...and i dont think i started noticing it at all until it started getting colder.
strange...what's the fix?
#492173 12/03/02 07:36 AM
Try pushing up & down on each corner first thing in the morning (or when it's doing it) to see if you can hear it or narrow it down to one area-you may have to regrease the stabilizer bar bushings-they usually make a rubber to metal squakking sound.
#492174 12/03/02 01:53 PM
Check your right rear e-brake mount. I found my squeak when I pushed down on the right rear of the car: the rubber finned bushing sqeaked like hell. I little grease later and it's been silent for 6 months.
1999 Red / Tan SVT #1969 of 2760 Built 4/21/99 K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links 17" FSVT 5-Spokes Factory Spoiler 35% Tint All Around
#492175 12/03/02 04:01 PM
#492176 12/03/02 08:13 PM
YOU TOO?
I have spent hours looking for this bastard and nothing!Sounds like a metal on metal rub....it shows up best with a full slow suspension travel,like going over a dip in the road.Not a bump.I moved my front brake lines around and it seemed to go away,but it came right back.Maybe I need to move them again and see.......
I AM WE TODD IT I AM SOFA KING WE TODD IT
#492177 12/03/02 10:54 PM
TGO Offline
Today was particularly cold, and mine was doing the same thing! At first, i thought I got something caught up under the car, so I pulled over and after lying on the ground looking like an idiot, I found nothing and took off..but the squeak was still there. When I got home, I couldn't recreate it by pushing down on the car, or grabbing inside the fenderwell and pulling up and down..but I opened the rear door (passenger side) and stood on the sill and started bouncing up and down and sure enough...squeak...squeak. Only seems to happen when cornering, or hitting pretty big bumps. What's the solution to this? New busings? I suppose I can wait until I lower the car to do it, would be the perfect time right?
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
